View Full Version : deadener on doors worth it?
lbluecamaro69
11-29-2013, 07:38 PM
i have a 69 camaro and i just finished laying dynamat on the back seat area, tubs, partition, and entire floor, i have just been wondering if it is worth it to do the doors? i do not have any speakers in them and if i should do them, which areas should i cover?
Motown 454
11-29-2013, 07:51 PM
I think it makes a big difference. I did it on my 69
lbluecamaro69
11-29-2013, 08:28 PM
did you do it on the inside of the outer skin or just the outside of the inner part?
Schwartz Performance
11-29-2013, 09:27 PM
Inside of the outer skin is flatter which makes the "tin" sound, it's most needed there. Dynamat type deadener is what I'm talking about.
-Dale
68lovebuzz
11-29-2013, 10:24 PM
Same. Works really well. Gives that door shutting "thud".
minendrews68
11-30-2013, 08:09 AM
If the Dynamat is installed on the inside of the door (outside panel, but inside the shell) wouldn't it tend to hold moisture?
icemanrd19
11-30-2013, 06:00 PM
the doors sound so much better.
http://i30.photobucket.com/albums/c302/icemanrld19/20130827_204701.mp4
Motown 454
11-30-2013, 08:55 PM
Sorry for the late answer I did it on the door skin.
lbluecamaro69
11-30-2013, 08:59 PM
Thanks guys looks like that's where I'll put it then
First Bird
12-05-2013, 05:06 PM
I put Dynamat on the inside of the inner door panel since I too was concerned about moisture. It helped a lot.
Nothingface5384
12-05-2013, 05:21 PM
Mainly the ccd matting like dynomat is for taking away vibration resonance from speakers or perhaps downpipes.
And you only really need 25% coverage.
To Combat heat takes a different matting
Same with air Bourne noises...MLV and ccf om wheelwells help with that
Def good to get moisture out like mentioned
