View Full Version : Ford 9" - Check My Pattern
TPIGuy
11-24-2013, 08:58 AM
Long time reader, first time poster. I bought a Ford 9 DSE quadralink last year and am just now getting around to setting up the gear set. It is a new center section and new gear set, so I could use a little help verifying the pattern. Thanks in advance!
85808 85809858108581185812
LS1-IROC
11-27-2013, 02:55 AM
Needs more work. Your pattern is too deep. Try using less gear marking compound as well.
TPIGuy
11-27-2013, 03:54 AM
'Too deep'. Please elaborate. Does that mean the Pinion needs shimmed out, or that the pattern is too deep in the gear.
Affirmative in the compound.
cdhowell
11-27-2013, 09:16 AM
Take .005 out of the pinion shims and try again.
bryant
11-29-2013, 10:32 PM
you will need to put a thicker pinion depth shim it. at least 0.005.
