View Full Version : 700r4
cutlassmann
11-18-2013, 05:15 PM
If I'm running 3.42 gear in a 10 bolt with 295-35-18 tires and if I go with a 700r4 tranny my motor is a 350 olds with a 520/523 lift my question will a 700 r4 be a choice to go with?
69cutlassrkt
11-19-2013, 09:14 AM
This may help you http://www.csgnetwork.com/multirpmcalc.html.
ammoyer
11-19-2013, 11:31 AM
If you plan on keeping the Olds engine, the only OD automatic that is available with the BOP bolt pattern is the 200-4R. All others, including 700-R4, 4L60/65/80 etc will require an adapter plate. Not a big deal, but something to keep in mind for you.
Steve Chryssos
11-20-2013, 08:09 AM
It will lug a bit in OD. A tight converter is recommended.
djfxall
11-21-2013, 03:52 PM
Did you ever go play on those sites I sent you to. My advise is really get what you want the first time. Don't do it twice.
