View Full Version : UMI LCA Relocation Brackets with Coilover Conversion for Chevelle
APinSoFla
11-10-2013, 08:47 PM
Hi All,
Does anyone know if UMI's bolt-in rear lower control arm relocation brackets can be made to work with Chassisworks' rear coilover conversion kit? I've attached a pic of what I think might be possible. I don't mind being a guinea pig but am wondering if anyone knows for sure that this will or will not work. This would be on a 70 Chevelle.
Thank you,
AP
APinSoFla
11-24-2013, 01:28 PM
I guess I get to be the beta tester.
Feel free to voice your opinions on either of the kits individually. Any problems with installation or reliability?
chevelletiger
11-26-2013, 07:37 AM
That plate can be removed and all you would have to do is grind the weld down on that umi bracket.bolt the chassis work bracket on and use a transfer punch to get the holes spot on where they need to be.also is the umi brackets plate thickness the same as the cac?
protour_chevelle
11-26-2013, 08:21 AM
Im in a similar boat right now lol. I'm thinking I'm going to draft up an all in one dealio. I have ridetech coilover brackets and umi relocation brackets. My car needs the LCA relocation brackets to keep everything happy.
