View Full Version : Jack stand placement
paulk68
11-02-2013, 12:10 PM
i want to remove my front subframe and rear springs on my 68 camaro. Where is a good spot to put jack stand? Are jack stands my best option for holding the shell up or do you guys use someting else?
thanks
BonzoHansen
11-02-2013, 01:32 PM
I initially did this, then rearranged a bit afterwards. Later I probably put jack-stands under the rear frame rails and removed the rear leafs & axle assembly as a unit although i don't really remember exactly at this point.
https://static1.pt-content.com/images/pt/2011/05/sfoff010kk-1.jpg
paulk68
11-02-2013, 03:13 PM
Thank you very much that picture is a big help
MIKE67
11-04-2013, 04:36 PM
Here is how I did mine.
https://static1.pt-content.com/images/pt/2013/11/Camaro35Mod_zps9ec5fcb9-1.jpg (http://s1224.photobucket.com/user/mike679/media/Camaro35Mod_zps9ec5fcb9.jpg.html)
https://static1.pt-content.com/images/pt/2013/11/Camaro19Mod_zps2696010d-1.jpg (http://s1224.photobucket.com/user/mike679/media/Camaro19Mod_zps2696010d.jpg.html)
NOT A TA
11-04-2013, 08:07 PM
I use wheel cribs and boards under the pinch welds or rocker corners depending on the car. Then prep & prime the front subframe mount areas before rearranging the cribs to support the car under the frame mounts so I can do the rest of the floor areas.
https://static1.pt-content.com/images/pt/2013/11/006_zps726b2edc-1.jpg (http://s240.photobucket.com/user/NOTATA/media/The%2014%20Car%20Performance%20Therapy/006_zps726b2edc.jpg.html)
https://static1.pt-content.com/images/pt/2013/11/013_zps13df1a1d-1.jpg (http://s240.photobucket.com/user/NOTATA/media/The%2014%20Car%20Performance%20Therapy/013_zps13df1a1d.jpg.html)
