    Results 1 to 7 of 7
      Oct 2008
      Seattle, Wa
      Are there any retractable 4 point harnesses out on the market?
      I like my 4 point harness now but it is really annoying having to deal with the lap belts every time I get in and out of the car. Is there a harness I can get that has a retractable lap belt?
      Jun 2001
      Orlando, FL
      None that I'm aware of. A 3 point harness is safer anyway, and you can get those in a retractable version.
      ​John Parsons
      Oct 2008
      Seattle, Wa
      How is a 3 point safer? I have never heard that before.
      1969 Camaro - LS7/T56 - Art Morrison Front Suspension/Ridetech Coilovers
      Instagram: @rbreezee88
      Jan 2009
      Huntington Beach CA
      Jun 2001
      Orlando, FL
      4 point harnesses will eventually not be allowed. Because they keep the upper torso farther back in a frontal collision, they tend to allow the body to slide down under the lap belt, which results in the lap belt causing severe abdominal injuries. 6 point harnesses with thigh-belts (sometimes called anti-submarine belts) that hold the lap belt in position are much better.
      A 3 point harness causes the body to twist during a frontal collision (plus all modern cars have belt retractors to tighten the belts significantly during impact) and so doesn't have the "submarining" problem. In nearly all cases a 3 point system is superior in a frontal collision to a 4 point system.
      If you go with a 6 point system, then you also need to use a HANS device, because they hold the upper torso so securely that your neck can't hold your head in place anymore.
      ​John Parsons
      May 2008
      Toronto
      Great post John.
      Most people don't realise that 4 point harnesses are not safe.
      I'm looking for a good seat right now to use with a 6 point harness.
      Jun 2001
      Orlando, FL
      Quote Originally Posted by Keith
      Here ya go:
      It's a Cobra Misano. It has provisions for both 6 point and 3 point harnesses. It has welded bars under the seat for the thigh belts, and it be mounted on sliders or a power seat rail and integrated with a 3 point belt. I just put one in my 07 Z06, and I have two on hand for my 69 Camaro project.
      ​John Parsons
