RIF RAF
10-20-2013, 07:39 PM
Pump Gas Street Build:
'76 400 Chrysler block - line hone'd w/ARP studs, CNC bore, square deck
.030 KB pistons @ zero deck
Recon'd Factory rods with ARP Bolts - full floating
Factory forged crank
Total Seal Rings
ACL RACE Main and Rod Bearings
Balanced and blueprinted rotating assembly - Internal Balance
Factory heads - Fully Ported and polished, New SI stainless steel valves, Comp Cams springs, retainers, and locks. Posi Seals. Milled .030 to make 9.7 to 1 compression
Felpro Gaskets
Milodon Oil pan
Comp Cams double roller timing set
Comp Cams 3 bolt cam - XE274 solid flat tappet
adv. 274/280 .050 236/242 lift .502/.511 LSA 110
Proform Shaft rockers
Comp Cams pushrods
Included but not pictured is intake, exhaust, & valve cover gaskets, Oil pump housing, filter adaptor, crank pulley, Flywheel, misc factory fasteners
Machined and Assembled @ Joe Mondello Racing Engines in Crossville, TN
Contact Cody
JMRE -931-459-2760
With a good intake, carb, and headers this engine will make around 450HP on pump gas.
$4500 as long block
$7000 Finished out with Dyno Tuning - Bolt in ready
You can pick up or will ship at buyers expense
83974839758397683977l
Total Seal Rings
Felpro Gaskets
Milodon Oil pan
Comp Cams pushrods
Contact Cody
JMRE -931-459-2760
$4500 as long block
