View Full Version : Need help finding a CV shaft
Motorcitydak
10-14-2013, 05:39 PM
I am looking to wrap up my front drive setup. Drivers side CV is a stock unit for a Cadillac STS. A custom center shaft is in the works and really not too hard to come up with. The problem child now is the passenger side shaft. I am using a front diff from a Trailblazer/Envoy which is usually mounted on the drivers side, I need it on the passenger side and have it mounted there now. The issues are that the seal diameter and shaft length are different. I had planned to simply have the large shoulder (40mm) turned down to the size of the center shaft collar (31.75mm). The issue however is that the the CV shaft is 5/8 shorter than the center. I cannot have the body turned down to lengthen the shaft. So....the issue now is that I am having a hard time finding a database of CV shafts to plow thru. I need a shaft with 26 spline, a seal surface of at least 31.75mm and a length of 4 1/4.
Issue #2 is that I will not have room inside the diff to run a snap ring to hold the CV shaft end in. The fit between the spider gear and CV are very tight, quite difficult to get in and out even without a snap ring. Would putting some lock-tite onto the splines hold the assembly for me? I really do not want to have to take the diff back apart to see if I can swap around the spiders since I just got it back from the shop, would rather not mess up the setup
Here is what I am dealing with, the blue tape on the shaft is where it meets the diff
https://static1.pt-content.com/images/pt/2013/10/DSCF2779_zps352010a6-1.jpg (http://s57.photobucket.com/user/motorcitydak/media/DSCF2779_zps352010a6.jpg.html)
Owen Wilson
11-06-2013, 10:54 PM
Great sharing here on this site...~
________________________
nutribullet-recipes.net (http://www.nutribullet-recipes.net/)
Tom Welch
11-07-2013, 04:22 PM
Give Cannon Racks and Axles a call. 912-927-7933. Bob has helped many folks with performance applications, he may be able to help you, too.
Motorcitydak
11-10-2013, 02:18 PM
Great, thanks a lot Tom. I had not come across them before
