View Full Version : 69 Camaro RS Protouring Project
rimspec
09-23-2013, 05:28 PM
Hi I am restoring a 69 camaro rs So I will be positing the build on it. I plan on using a ls1 motor from a 1998 camaro ls1 here is what I will be building from. Looks kinda rough but I have a vision for it. I was thinking of protouring it unless you guys think I should do something different.
This is the donor a 1998 camarao z28
rimspec
09-23-2013, 05:29 PM
Here some more updates took the fender off fixing imperfections on the body and customizing it
Taking dfenders off and fixing imperfection and getting ready to powder coat the sub frame
rimspec
09-23-2013, 05:30 PM
some more updates
decided to do jet black pearl and a touch of yellow
rimspec
09-23-2013, 05:31 PM
okay now we are fitting up the engine and getting things ready notice the whte z28 donor car
engine mount installation
engine mount customization
engine mounts installed
new oil pan need for the swap
removing old oil pan
installing new oil pan accessories
oil pan installation and fitment
aftermarket savini forged rim fitment
rimspec
A couple more updates that we have concerning our camaro project. Hope this explains some the camaro restomod progress.
here a picture of the engine put in we had to mod the subframe frame ane wreweld the piece that we notch back back in once done with all the fitment we will repowder coat the subframe.
custom fabricated drive shaft
fabricated gas tank built from a 98 camaro z28 and 69 camaro gas tank
rimspec
09-23-2013, 05:32 PM
Okay we Have more updates
Okay Here some more updates what we done is our big brake kit came in we did all four front and back the lug nuts where to short so we order some studs from jegs. If you ahve a project like this and it seems hard let us know we can do it for you..
Remove pins from the 69 camaro rear differential so we can take out the axle so we can do a rear disc brake conversion
Taking out the axle on the 69 camaro rs so we can apply the big brake kit
Big Brake kit for the 69 camaro rs partial install
Cross drilled slotted rotors installed for the 69 camaro rs
Finally the windshield came in and we installed the window minus the molding for the 69 camaro since we are going to do black chrome on the mouldings
We went ahead and installed the original 69 camaro rs rear window also
Stay Tuned for more .....
rimspec
09-23-2013, 05:33 PM
Okay we got a couple more updates we had some time to install the custom ac bracket for the ls1 in the 69 camaro rs and we purchased the sanden 508 compressor in chrome. we had to get a new belt for this setup which was a gates k060980 and it worked perfect. The tensioner we had to get was the gates #38164. We used the old pulley off the old tensioner also which is listed or shown next to the new tensioner
notice us configuring the tension the pulley above was from the old stock tensioner
making some final adjustments on the ac bracket and belts
notice the chrome sanden 508 not bad on pricing the bracket cost more then the compressor :(
Buryingthesun
09-23-2013, 05:42 PM
looks great! I like the rear vent ducts, but whats up with the yellow?
rimspec
09-23-2013, 07:04 PM
It our company color black white and yellow
rimspec
10-04-2013, 12:19 AM
some more updates installed some dynamat
put some interior in
fabbing some abs brackets
rimspec
10-08-2013, 06:04 PM
tried a set of vossen and lowered the camaro any feedback?83476
rimspec
05-10-2014, 11:09 PM
Here a couple more updates on the camaro
95450
95451
custom build center console fab by us
95454
95453
Some Seats
95455
rimspec
05-10-2014, 11:17 PM
any feedback from anyone?
stevenp0827
06-13-2014, 05:58 PM
Nice work, like the wheels in black. (Yellows not in my taste but appreciate the fab work on the vents).
Nice work guys, but these weels were more my taste !
Yellow don't hurt me, maybe paint also the calipers, rear-view mirrors & tail pannel in yellow would match ?
Nice work with console & seats !
My 2 cents
Gil
