View Full Version : Diff Gears Change
epeterson
09-16-2013, 02:03 PM
Hey guys I have a question about the differential gears. If I wanted to change 4.11 gears to 3.73 how much would that cost me to take it to a shop and have them do it? Thanks guys
Ron Sutton
09-16-2013, 02:43 PM
Most shops are $200-$250 for labor plus parts. Some are less.
Where are you ?
mitch_04
09-16-2013, 03:04 PM
Just so you know, this probably doesn't qualify for the "Emergency Room" section. That being said, Ron's post seems to be pretty close. Are you planning on replacing bearings and such while you are in there, or just gears?
andrewb70
09-16-2013, 03:13 PM
I just had this done and it was almost $600. That included labor, new R&P, and all new bearings.
Ron Sutton
09-16-2013, 04:12 PM
I was going to say "around $550" with gear & bearings. But the price depends on brands.
epeterson
09-16-2013, 04:50 PM
Im in chicago
Ron Sutton
09-16-2013, 05:04 PM
Im in chicago
Hmmm. I know several good places across the country, but I don't have any experience with shops in Chicago.
andrewb70
09-17-2013, 07:57 AM
To clarify, that was with a Motive Gear gear set and Timken bearing.
Ron Sutton
09-17-2013, 08:05 AM
Thanks Andrew,
Have you driven the motive gear yet? If not, let us know how the sound is. I think many guys are looking for quiet gear sets.
ccmc
09-17-2013, 11:17 AM
I was just quoted 200-250 for installing new bearings and ring & pinion with me supplying all of the parts. This is in Sacramento, CA
Ron Sutton
09-17-2013, 11:58 AM
Which shop ?
sccacuda
09-17-2013, 01:51 PM
I charge $325-375 labor for a gear change depending on what rear. I will ONLY use Timken US bearings and depending on the rear, the kits run $125-$175. Gears are another story altogether. For daily drivers I strongly recommend OEM gear sets for noise. If it is anything else, I make the customer supply the gear set.
Lots of guys will do the $200-$250 swap, but they are simply swapping parts, reusing the same shims and hoping for the best. Rear gears have to be setup with the proper tools to get the best longevity and lowest noise possible. This isn't the $50 Raytech pinion depth tool. I have a set that is an OEM tool and VERY accurate for setting pinion depth and backlash/preload, a dial torque wrench for setting turning torque for pinion bearing preload, and a non Chinese dial indicator. I would look for a shop with quality tools that isn't afraid to show you what they use to setup gears.
ccmc
09-17-2013, 02:40 PM
West coast differentials
Ron Sutton
09-17-2013, 04:03 PM
Good advice Craig !
Ron Sutton
09-17-2013, 04:04 PM
When we're not doing them ourselves internally at our shop, that is who we use & recommend.
