View Full Version : disk brakes for 8.8?
rcrown
09-14-2013, 08:05 AM
Looking for disk brakes for a shortened 8.8 axle with big ford 9" bearing ends that seems to work on this housing, what has been used, how was the installation completed?
Thank you
zimsport
09-16-2013, 01:19 PM
Any kit for a 9inch housing end will work. Wilwood has a few options.
dontlifttoshift
09-16-2013, 01:36 PM
There are two Big Bearing Ford patterns. The late style or Torino style will have a 2 1/2" offset from housing end to axle flange and will use 3/8" bolts. The early Big Bearing Ford will use 1/2" bolts and could use a different offset. The bolt patterns are different between the two.
http://www.wilwood.com/BrakeKits/BrakeKitAxleFlange.aspx
I highly recommend a floating caliper with an 8.8 rear end.
ccmc
09-17-2013, 02:49 PM
Can't you just use an explorer disc set up?
