View Full Version : LS with carb or SBC
paulk68
09-12-2013, 03:49 AM
So I really want to try to keep the classic look of a carb and air cleaner for my 68 camaro project. My question is should i do a ls engine with an intake and carb or just stick with a traditional SBC. my LS option i am looking at is the katech LS hot rod motor. Or my other SBC option i am looking at is the daily driver 427 series from nelson race engines. What do you guys think? does any one have one of these engines?
thanks
Todd in Vancouver
09-12-2013, 07:02 AM
Personally, after already building a SBC, if I could go back I would do the LS. You want a carb now but if you want to change it later you will already have an LS to build upon. I've got a nice SBC but now I'm limited and will end up changing later to an LS.
andrewb70
09-12-2013, 07:29 AM
If you want the look of the carb, you can do a carb style intake on the LS engine but still use EFI.
paulk68
09-13-2013, 12:21 AM
That is what I was thinking, i have been looking and have not really found many options for that style do you have any recommendations? i thought Mast mad eone but i can not find it on their site.
kiwigt
09-13-2013, 01:06 AM
Here it is
http://www.mastmotorsports.com/2010/news-view.php?id=49
Schwartz Performance does one also
http://schwartzperformance.com/billet-ls-vertical-throttle-body-adapter/
andrewb70
09-13-2013, 05:08 AM
Here it is
Those are great options if you want to use a DBW throttle body.
If you are using a cable throttle body, then you can use any number of other options. Holley makes a couple of manifolds, including the Hi-Ram and a dual quad. Edelbrock makes a single plane intake.
67rally
09-16-2013, 09:59 AM
Here's my setup. 6.0l LQ9, Edelbrock Vic Jr. LS1 EFI intake (29085), Accufab 4150 TB (DBC). Edelbrock fuel rails, and coil covers.
https://static1.pt-content.com/images/pt/2013/09/LQ9364_zps9e75fcb1-1.jpg (http://s228.photobucket.com/user/modi_photos/media/LQ9364_zps9e75fcb1.jpg.html)
alocker
09-18-2013, 04:09 PM
Nice looking setup. What ecm and harness are you using?
67rally
09-19-2013, 06:34 AM
Thanks. The ECM and harness are from PSI Conversions.
