    Results 1 to 8 of 8
      Nov 2011
      Glendale, AZ
      Will 67 Camaro Door Panels fit a 68?
      I looked all over the net, but have been unable to find the answer....soooooo, can I fit a 1967 Camaro door panel on my 1968 Camaro? If so, where do I buy that upper metal piece? Right now I have my 1968 door panels, but they are beat up pretty bad. Thank you!
      Randy
      Lawrenceburg, TN
      no....the upper metal piece on a 67 camaro is part of the door not a bolt on item
      Nov 2011
      Glendale, AZ
      Ok. Thank you.
      Jonesboro, Arkansas
      I just took apart the door panels in my '68, the bottom's of the door panels were gone, I took them apart and salvaged the top metal piece, and the stainless steel trim pieces, front and back. Now I'm thinking about just buying new panels.
      Carl
      Carl Wilson
      Lawrenceburg, TN
      Quote Originally Posted by minendrews68 View Post
      Carl
      perfect and buying un-assembled panels and adding your upper metal saves a TON of money and is pretty easy the hardest part was putting the window felt on
      Nov 2011
      Glendale, AZ
      That's pretty much the same boat I am in...I have the complete panels now for my 68 (front and back), but the bottom portions look like Swiss cheese. Where do you buy just the bottom portions of the panels for the 68s? Do you have a link?
      Lawrenceburg, TN
      Quote Originally Posted by Fras View Post
      hope that helps
      68 Camaro front door panels classic industries
      Jonesboro, Arkansas
      one is TMI parts, and a reseller for them is "Camarointeriorparts.com"
      carl
      Carl Wilson
