View Full Version : What to Do... c6 calipers hit Spokes Help..
XLexusTech
09-07-2013, 12:11 PM
by maybe 1/4 inch... any issue running a spacer or it better to have the wheels cut? Cutting the wheels is something i would rater not do..
But if spacers are dangerous? thinking 1/4 inch maybe 5/16 needed..
icemanrd19
09-07-2013, 12:31 PM
spacers arent the best but as long as you have good wheel studs you should be fine. We are only talking a 1/4" Get longer APR studs and get the min spacer to fit. All you are doing is making the rim hat thicker. What about fender clearance though running a 1/4" spacer? Do you have enough clearance?
I do not like the spacers that bolt onto the hubs i like a full spacer that in a way acts as a washer. Can someone weld a spacer onto your existing rims? Make sure you install the rotors and everything so you know the exact space that you need
XLexusTech
09-07-2013, 01:02 PM
Not sure about the fender... going to order new wheel studs and some spacers.. may go 3/8 just to be safe.. if I have to clearance the fender lip.. so be it.. Did some reading on some vette forums and its pretty common... kinda wishing i went with the Bear brakes right now :-(
Rick Dorion
09-07-2013, 02:35 PM
If the clearance is tight you may be able to add a bit more negative camber to resolve. On my 69 with C4 brakes, I ran a 1/4" spacer for 10 years. I also used button head bolts in the top of the wheel well and 1* negative camber.
XLexusTech
09-07-2013, 03:02 PM
Mod delete .. double post :-(
icemanrd19
09-07-2013, 06:21 PM
sell your z06 brakes and but the correct ones then. They should sell quick
raustinss
09-07-2013, 07:52 PM
I'm in need of some Z06 rotor and caliper for the front.....already have rears
