View Full Version : Questions Before 1st time Fire on LS
67CamNKC
08-01-2013, 04:40 AM
Long story short, I am on yr 6 on my build. I have a short term goal to hear the engine fire, even if only for a minute (a little accomplishment to keep on keepin on). I have my PSI harness and ECM and I have my AAW classic update harness that I am starting to install.
Can someone give a quick list of what the engine requires to run? I know the normal stuff, but what about MAF, coolant sensor, IAT ect.
Next question, I have a GTO T56 installed. No drive shaft but has a factory cap over the shaft. I have my new slave and braided bleeder lines installed but no clutch master. Will there be a problem cranking and running the engine for a quick few seconds or minute?
Shannon
no go nova
08-01-2013, 05:12 AM
should be good to go. but add the sensors in.
67CamNKC
08-01-2013, 05:15 AM
I definitely will add them in, but will the engine run without the MAF and IAT? Right now, I only have the sensors on the throttle body, but nothing farther out hooked to it.
Reactor
08-01-2013, 05:54 AM
My LS3 Crate would fire without the MAF but would quickly die. As soon as I mocked up the intake with the MAF in it, it ran fine. Not sure about the IAT.
joeljet
08-04-2013, 06:19 AM
patience padawan hook it all up then fire it up, don't want to be chasing a gremlin that turns out to be some stupid little switch or ground wire. as far as year 6 i'm going on year 9 and you're stiil farther along than my 73 formula, ls 408, t56, ridetech, etc, etc. good luck and don't give up
65 drop top
08-04-2013, 08:46 PM
Sorry if I'm stating the obvious and or asking a question, but don't you need to prime the oil system before starting it up after its been sitting for a while.
67CamNKC
08-05-2013, 04:12 AM
There's not an easy way I know of on an LS. I went overboard on the assembly lube when I built it.
CarlC
08-05-2013, 06:38 AM
I removed the spark plugs and turned the engine over in 15 second intervals / starter cools to get the oil pressure up. It came up pretty quick.
SSLance
08-05-2013, 07:37 AM
On some of the HorsepowerTV episodes I've seen them use some sort of a pressure pump they hook air up to in order to pressurize the oiling system in LS motors before first fire up.
badazz81z28
08-05-2013, 03:19 PM
I highly suggest this. I would not spin the engine over to prime it (at least initially). I made my self a priming tool out of a garden sprayer.
