    Results 1 to 13 of 13
    Thread: ABS plastic?
      Oct 2007
      ABS plastic?
      Anyone have a good product for repairing ABS plastic? The corner of my guage cluster (the tab) snapped off and i have another one which is also damaged that I want to piece in the Tabs from (67/68 camaro) sppedo and Tach cluster.
      67 Camaro In progress
      Feb 2006
      Tennessee
      I'm thinking you need a plastic welder.
      66 Chevelle - LS-Leap
      LQ9 / T56 Complete - Phase 2 in process!!
      https://www.pro-touring.com/threads/...t-LS-Heap-quot
      SC&C, Kore3, Detroit Speed, BBS, Advanced Induction, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock LS-Kit, Mast, Wilwood, BP-Automotive, StopTech, Ridetech, Hotchkis, UMI, Energy Suspension, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
      Oct 2007
      i saw some posts about JB weld Platic repair, I may go with that... anyone have any feedback on it?
      Winters,Ca
      ABS plastic?
      We sell a product called Q-Bond. Its a glue with a powder. This stuff works great on plastics
      Aug 2010
      New Albany IN.
      I read on the Corvette forum where someone wrote about making ABS plastic paste from a piece of ABS plastic cut up into tiny pieces and soaked in acetone. The acetone melts the abs and makes it like a paste. You then use the paste to fill the crack and as it dries the acetone evaporates and you are left with a solid piece that you sand smooth. I've never tried it but i eventually will
      Oct 2012
      Dichloromethane (methylene chloride) works better than acetone. A company called Plexus makes MA300 a plastic adhesive that works amazing.
      Oct 2007
      I used the JB weld plastic repair... so rar.. its been awesome! will see how well the repair holds up
      Oct 2010
      Carlsbad, CA
      Go to Home Depot. They have ABS Weld in the plumbing area.
      Current Stable
      '68 Camaro SS
      '13 Audi S4
      '99 Mazda Miata converted to Spec Miata
      '04 F350 Diesel
      Out to Pasture
      '06 BMW M3
      '05 Factory Five Cobra
      '07 Ultima GTR
      '06 Corvette Z06
      Nov 2011
      Joliet, Illinois
      We have tried many, I can tell you that CA+ Zap a Gap, is what works best for us. Readily avail at many hobby shops. It can be used by itself or with the accelerator, that instantly dries it solid and tight. Will not break off in that spot again.
      Good luck
      Sep 2013
      Quote Originally Posted by corvettekid1973 View Post
      there is a high likelyhood that it was a post i wrote in. I think i brought the idea over from the mp3car forums and was one of the first to use this method on the double din mod to the c5 dash. Mek works best for melting the plastic. Using this method you chemically 'weld' the pieces together making a flexible repair with similar properties to the original piece. Another method is to heat weld the piece. I've done this with luck too. they have welders out there or if you get an old broad tip soldering iron (with temp control) you can hack in a repair as well.
      May 2010
      kitchener,Ontario,Canada
      Any plumbing supply store will sell abs pipe glue and primer..anyone ever try and move a abs pipe joint seconds after you glue it ? Never will happen it's cheap also less then 5$ if I remember correctly
      Best of luck Ryan
      Sep 2013
      Best of luck Ryan
      that is a good suggestion. you may want to add some more material to the backside in order to increase the surface area of the bond. though
      Nov 2010
      Metro Memphis, TN
      I think modeler's glue is nothing more than a gel form of MEK. Seems to work good for the model cars that kids build; I see no reason it wouldn't work for interior parts. I would consider melting some plastic shavings and spreading it on the backside for reinforcement
      I'm not a mechanic, but I did stay at a Holiday Inn Express last night.
