View Full Version : Pro Touring 1980 TA
mobandit
07-10-2013, 05:52 PM
Hey guys im working on my 1980 trans am used to be my fathers car a while ago and he gave it to me when i was 13 so now 10 years later I'm ready to build this car the way i think a trans am should be. The car has DSE mini tub kit and tubular a-arms 2" lowering springs and solid body bushings. The engine is a 461 Stroker Pontiac making 550Hp 600Lb ft of torque backed by a Tremec t56 Magnum trans with a mechanical clutch bellhousing from quick time. The rear is a fab9 narrowed with true trac and 3:89 gears the wheels are 18x9 and 18x12 Year One billet snowflake wheels and the whole thing is going to stop with C6 zo6 brake kit from kore3 and a hydroboost set up by hydratech im having a roll bar welded up inside and Corbeau A4 seats and im going to fit autometer gauges in the engine turned dash bezel
This is how the car started
79050
Then it went into paint jail
79051
79052
79053
Then the mini tubs were installed
7905479055
Mean while i worked on restoring the subframe I had it sandblasted and i painted it with POR15 and added new stainless fuel and brake lines
79056
79057
Had the firewall smoothed
790597905879060
Then the body was mounted on the subframe
79010
79011
79012
Then Finally the fenders
79013
Bolted up the rear suspension
79014
79015
And finally the car sits on the ground again
79028
79029
79030
79032
79033
79034
instro84
07-10-2013, 07:40 PM
Nice love those 2nd gen ta's
TRANSAMERICAN 79
07-14-2013, 09:28 AM
Alright! Lets go for another second gen bird, loveum
72blackbird
07-14-2013, 09:35 AM
Good work on your T/A- thanks for keeping it Pontiac Powered. What size rubber do you have on your original snowflakes? It doesn't look too bulgy for 15's and I need new rubber for my 76 TA.
Geno
70Uglybird
07-16-2013, 07:32 PM
Looks great!!! Lots of trick parts in there! Can't wait to see more!
