cactuss4
07-03-2013, 08:05 PM
Obviously this can fit into suspension category as well, but was not sure.
The discussion is centered around 66 Chevelles.
I've found a couple of prostreet cars that appear very clean, but those big tubs give me pause. Now for a pro-touring car, it gives me lots of room for wheel tire combo's, however, get too big I'm just going to make whatever I get push really bad (I guess if there is enough power and I can make it rotate with the go fast pedal, that may not be an issue), however I'm asking from a track type car is having tubs a bad thing, if I can work around it and get back seats and interior back in place, modify the cage to allow direct access to the backseat for non track days etc, is there a problem with having a full tub on a car?
Obviously things like geometry with the rear axle/diff is concerned, a wider track will be better (shortened diff with full tubs), but the wider track could be made up again with a wheel tire combo. So if one can figure out how to reinstall, recreate a rear seat etc. is there a true negative to having a full tub in a non prostreet car?
Is there a chassis concern, is there a true negative, other than having a cut up car (I know!). Appears one can fit a 295 already in the back of a 66/67 , a few have stated 315's, so more tire is maybe not a big concern.
So to recap, full tubs something that folks would not due if they had the choice, and why (other than cutting up the car). Just curious as to understand the pro's and con's, if there are either?
Tory
Tory
