View Full Version : transmissions and driveshaft
thegreek
07-02-2013, 11:13 PM
I just bought an $800 aluminum driveshaft for a th350 and realized i want a t56. will this driveshaft match up to the t56??? HELP
Schwartz Performance
07-03-2013, 04:53 AM
The T56 is longer so you'll have to get it shortened. $800 seems a bit steep for an aluminum shaft though.. Must have an expensive slip yoke? You can reuse your slip as long as you're not using a T56 Magnum.
-Dale
thegreek
07-03-2013, 10:43 AM
yea i know it was alot of money but they make the best around. but alls ill have to do is get it shortened and reuse the same yoke
thegreek
07-04-2013, 03:22 PM
Also wondering if the spline on the driveshaft thats in the th350 would fit the t56 transmission
riles
07-18-2013, 08:59 AM
I don't believe so. I believe the Th350 is 27 spline output and the T56 is 31 spline(at least on the magnum). If thats what you're asking.
