- TKX crossmember (6 replies)
- Torque On Transmission Cross-Member? (0 replies)
- Nissan CD009 /LS setup in a Chevelle (0 replies)
- Throw out bearing recommendation (4 replies)
- Noisy TKO (4 replies)
- Tremec TR5050 5Spd? (3 replies)
- T56 gear ratios, final gear ratio..... thoughts (7 replies)
- Crossmember for Magnum and 3.5-4" Exhaust (0 replies)
- Bowlers T56 Magnum or Chevrolet performance T56 Magnum (4 replies)
- What to TIG clutch master pushrod with? (2 replies)
- T56 road race autocross options (2 replies)
- Stiff Clutch (10 replies)
- 2014 Mustang GT 5.0 6 speed Barton shifter install. (0 replies)
- What is my transmission worth? (2 replies)
- Hydraulic Clutch Decision: Bowler vs Mdl (12 replies)
- Trouble bleeding hydraulic clutch (5 replies)
- Hydraulic Fluid Recommendation (2 replies)
- Can you tell which Tremec 5 speed this is by these two pictures? (2 replies)
- Need a hydraulic clutch master for a 67-68 C10 (3 replies)
- TKX or Magnum in 70 Nova (20 replies)
- Gear Vendors overdrive in 1968 Camaro (6 replies)
- Trans opinions? (7 replies)
- Center force (3 replies)
- Hydramax TOB with ls7 clutch (2 replies)
- PPG Sequential Gear set ratio (7 replies)
- McCleod TOB noise at 1st startup COLD (2 replies)
- Which bell housing to use for L96/LS3 and TKO600? (1 replies)
- T56 Mag case casting/trans tunnel interference & Off center case casting (3 replies)
- T56 shifter that doesn't leak???? (8 replies)
- Need a clutch for a L96 6.0 and TKO 600 (2 replies)
- Reverse lockout controller (2 replies)
- T56 Magnum Shifter (35 replies)
- Which clutch kit is this? (9 replies)
- 1st Gen Camaro shifter location (0 replies)
- Any truth to the T56 Mag F 4 bolt shifter working better/smoother than Std 6 bolt ? (8 replies)
- Any one with opinions on Modern Driveline’s Superior Kevlar clutches? (3 replies)
- T-10 Transmission and High torque starter issues. (6 replies)
- Tremec t56 Magnum or Chevrolet t-56 Super Magnum? (7 replies)
- Help with bleeding hydraulic clutch (7 replies)
- 69 Firebird L92/T56 Wilwood Hydraulic Clutch - Yeah that's a problem (3 replies)
- Hydraulic throwout bearing suggestions? (5 replies)
- Damaged bellhousing dowel holes - very loose offset dowels (1 replies)
- Hydraulic clutch pedal adjustment (3 replies)
- T56 magnum with Ctsv bellhousing with pump (1 replies)
- Hyd clutch questions (6 replies)
- 69 Camaro Hyd clutch!!!! (3 replies)
- TKX or T56...Looking for input (14 replies)
- Advice needed for switching to hydraulic clutch system (3 replies)
- New Bowler Magnum F shifter install (3 replies)
- T56 shimming questions.. (10 replies)
- S1 Sequential T56 Magnum (1 replies)
- Which GM bellhousing for a GenV L87/T56 Magnum pairing (2 replies)
- T-56 Fluid pump and cooler, Why and how? (2 replies)
- Muncie rebuilding recommendations (2 replies)
- Hdy Clutch Master firewall bracket issues (10 replies)
- Used TR6060 out of a '15 Camaro questions (3 replies)
- T56 rattle (6 replies)
- T-56 old & new, difference? (1 replies)
- T56 shifter clearance (4 replies)
- G8 TR6060 vs Camaro TR6060 (2 replies)
- Tkx vs t56 magnum (4 replies)
- Hydraulic clutch pedal needing adjustment. (20 replies)
- T56 magnum VSS sensor part #? (1 replies)
- TKO600 upgrades? Service? Parts? (1 replies)
- Feedback on the MDL Quik Stik Shifter on a T56 Magnum? (0 replies)
- Gen 5 LT5 / T56 Clutch choice (5 replies)
- Indexing Plate T56 (2 replies)
- Tremec tr6060 (0 replies)
- LQ4 to TKO600 (4 replies)
- Bowler vs sst shifter (5 replies)
- putting a t56 magnum in my 82 c3 corvette (0 replies)
- Lt1 t56 to gen1 sbc (6 replies)
- Pilot Bearing Install Question for LS Engine. How do I know if this is right? (3 replies)
- Ideas for clutch pedal stop Gen 1 Camaro (16 replies)
- Holly Clutch master cylinder. Looking for feedback (5 replies)
- Clutch Pedal too light t56 Mgnum (2 replies)
- Clutch Self bleeding (4 replies)
- LSA to Magnum F Clutch and Bellhousing Fitment (4 replies)
- T56 magnum upgrades for big HP (6 replies)
- Driveline shakes BAD (20 replies)
- Advice on close or wide ratio T56 (13 replies)
- LS3/TR6060 swap into a 68 Camaro (4 replies)
- 71 Nova Hydraulic clutch help. (2 replies)
- 67 Camaro tunnel question (1 replies)
- T56 Magnum Yoke confirm. (3 replies)
- Tunnel cut for shifter... (8 replies)
- Clutch Slave Height (0 replies)
- Pilot bearing for T56... (5 replies)
- Removing factory bell housing dowel pins? (2 replies)
- T56 long term storage (4 replies)
- Clutch over hang on flywheel (5 replies)
- Bell housing alignment analysis... (15 replies)
- What Clutch Master to use? (8 replies)
- Tremec - Swapping out .64 for .82 5th gear in TKO 600 (4 replies)
- Speedtech Trans Crossmember Mounting Location (1 replies)
- Hydraulic Clutch or Mechanical (9 replies)
- LS clutch pedal travel (4 replies)
- tkx or t56mag to replace ar5 (2 replies)
- New Tremic 5 Spped (1 replies)
- Tremec T56 Magnum 6sp Problem (Won't engage 1st or 2nd Gears) (3 replies)
- Hurst T56 Magnum Shifter Exploded View of Design (9 replies)
- T56 Magnum Short Throw Shifters? (5 replies)
- Clutch and flywheel recommendations... (10 replies)
- Bell housing recommendations... (10 replies)
- Tremec TKX (67 replies)
- Bowler Nightstick offset shifter T56 (0 replies)
- Silver Sport T56 Magnum in 67-69 Camaro (5 replies)
- Questions on swapping 68 Camaro from Auto to Manual trans. (8 replies)
- BAD vibration TKO600 (8 replies)
- Pressure building inside transmission (1 replies)
- T56 Magnum - temp sensor location? (4 replies)
- Trans Mount ID Help Needed - T56 Magnum (1 replies)
- T56 Slave shims and centering of teh slave after install? (6 replies)
- Bellhousing for L92+ T56? (3 replies)
- Help with Broken TKO 600----5th and Reverse Shift Rail (Part Number 2605823) (0 replies)
- Leaking T56 Shifter (15 replies)
- TKO 600 BBC Which gear? (11 replies)
- LS7 T56 magnum and LS9 clutch (9 replies)
- T56 Magnum slave cylinder measurements (4 replies)
- T56 magnum VSS question. (2 replies)
- Anyone convert a Muncie M21 to an externally mounted hydraulic slave set up? (22 replies)
- ZZ4 - Lt1 T56 Flywheel? Help! (7 replies)
- GM/Tremec ACD 12453263 bellhousing dial in needed? (7 replies)
- Clutch master mounting (14 replies)
- ST 10 to TKO 600 swap (0 replies)
- Should I have shimmed the clutch slave? (8 replies)
- Which cross member to use? Limited options. (0 replies)
- TKO 600 whine in 4th and 5th (14 replies)
- 5 SPEED- Transmission KIT for GM A-body 64-67 (4 replies)
- LS vs LT T56? (6 replies)
- Dual Clutch Transmission (DCT) (84 replies)
- Throwout bearing Spacers (3 replies)
- T56 2nd gear grind (3 replies)
- Clutch disengaging too far? (7 replies)
- Tremec trans id (4 replies)
- TR6060 w 6th gen console shifter (2 replies)
- 1st Gen Clutch Pedal Geometry (4th Gen) Template or Measurement info..? (2 replies)
- Spin driveshaft by hand to test clutch disengaging (9 replies)
- Tko600 csc (14 replies)
- American powertrain six speed swap help (8 replies)
- Magnum rear seal (5 replies)
- Magnum Shifter Gate (6 replies)
- T56 Magnum trouble (8 replies)
- Which McLeod clutch to go with? (12 replies)
- Tr6060 slave to -4 adapter needed (2 replies)
- Not sure if it’s a trans issue (20 replies)
- TKO Shifter Upgrades (8 replies)
- Transmission shop in LA (0 replies)
- T-45 Question (2 replies)
- ls3 and tr6060 in 1967 camaro (1 replies)
- t56 magnum external cooler (10 replies)
- Dakota Digital speedo calibration frustration!!! (8 replies)
- T56 magnum shifter location for factory console 1970 Firebird (6 replies)
- Rubber transmission mount, TKO 500/600 type - some info (2 replies)
- 383 SBC to LT1-T56 HELP (6 replies)
- tko600 to t56 magnum for autocross (4 replies)
- Shifter length - 8" or 10" ??? (4 replies)
- TKO 600 to BBC Muncie Conversion (1 replies)
- Clayton pedal assembly worth it? (12 replies)
- tr6060 fast bleeder install advice? (0 replies)
- t56/ls7 clutch - Stiff clutch pedal after bleeding hydro master cylinder (15 replies)
- American Powertain T56 Magnum kit - going road racing (2 replies)
- T-56 Adjustable Transmission Crossmember Flex? (6 replies)
- TR6060 driveshaft for 69 Camaro (1 replies)
- Magnum swap woes (2 replies)
- T56 Magnum - am I the only one frustrated by the gearset choices? (45 replies)
- Transmission crossmember ‘67 camaro TR6060 (13 replies)
- t56 Magnum with 370 gears and wide ratio (7 replies)
- t56 help (2 replies)
- T56 Magnum Bellhousing Alignment Help!! (3 replies)
- 1st gear ratio choice TR-6060 for big power (6 replies)
- clutch pedal stop suggestions (6 replies)
- Best Clutch for LSA (9 replies)
- TKO 600 not smooth between 1st and 2nd (12 replies)
- Speed sensor question T-56 (3 replies)
- clutch pedal slop (1 replies)
- TKO600 install (6 replies)
- T-56 install in a 1980 Firebird - Change from Auto to Standard! (6 replies)
- Clutch line size (1 replies)
- T56 bellhousing alignment - Quicktime (38 replies)
- Shipping a trans???? (6 replies)
- Auto trans to TKO 600 conversion - clutch cable options? (8 replies)
- TR6060 MG9 clutch setup for 1968 Camaro (0 replies)
- LS7 Clutch TKO Master Cylinder Bore size? (5 replies)
- Move shifter closer TKO600 (2 replies)
- Help with transmission decision (5 replies)
- Shifter boot base install (3 replies)
- T56 magnum transmission (36 replies)
- Question on T56 speed sensor (4 replies)
- Sealing shifter hole? (20 replies)
- TR6060 swap - clutch disengagement question (2 replies)
- LS9 T56 Swap (3 replies)
- Parts needed for T56 in 67 Camaro... (3 replies)
- 68 Camaro Richmond 4+1 street speed question (4 replies)
- clutch recommendations (15 replies)
- Hydraulic clutch in 1970 chevelle (5 replies)
- McLeod T/O bearing 69 camaro TKO 600 (7 replies)
- used T56 or Magnum (4 replies)
- TKO 600 Second Gen Speedometer Calibrate (3 replies)
- Question for the drive line Gurus. (9 replies)
- Any aftermarket DCT transmissions on the market (0 replies)
- Auto to manual swap questions (2 replies)
- Tremec TKO and 1969 console shifter stick (2 replies)
- Nova with T56 (2 replies)
- TKO 600 Install.."the bolt" (3 replies)
- CTSV/ZL1 Bellhousing / T56 Magnum input shaft (8 replies)
- Bowler All-In-One Wrong Speed (10 replies)
- TKO600 Noise in 66 Biscayne (6 replies)
- T56 magnum input shaft into pilot (9 replies)
- NEW TKO Install- (Grease what?) (3 replies)
- G Force modified Tremec 3650 (0 replies)
- Lakewood scattershield working with LQ9 LS swap / TKO600? (5 replies)
- Can you ID this trans???? (10 replies)
- Stock LS bellhousing or Quicktime? (2 replies)
- T56 magnum with ctsv bellhousing oil pump question (2 replies)
- Hydraulic clutch master cylinder alignment (4 replies)
- T56 Magnum BBC Pilot Bushing (3 replies)
- Finally found a T56! But have some questions... (1 replies)
- First Gen Camaro Clutch Pedal Height (3 replies)
- Tko600 shift stick rattle (0 replies)
- T56 magnum info needed (11 replies)
- T56 advice needed (4 replies)
- TR6060 in a 68 camaro? (3 replies)
- LSA swap in 69 camaro (2 replies)
- tremec guide pin backing out (2 replies)
- Gear indicator (11 replies)
- LS3 clutches!!! (2 replies)
- 5 Speed OD opinion. TKO 600 vs Richmond Super Street (10 replies)
- Best T56 bleeder extension? (4 replies)
- T56 Magnum master cylinder (5 replies)
- Help with bleeding new clutch MC. (7 replies)
- American Powertrain HRB shim question. Shim bell housing or tranny? (0 replies)
- Having a hard time deciding TKO 600 or T56 69 for my mustang. (18 replies)
- T56 install - where are you connecting your back up lights? (3 replies)
- external Slave T-56 magnum? (11 replies)
- which flywheel for LT1 t56 bolted to old SBC (13 replies)
- Challenger Tr6060 using t56 clutch/flywheel? (8 replies)
- O.E. TR6060 to Magnum ?s. (11 replies)
- Single vs twin disc clutch (8 replies)
- Used T56, what to look for... (7 replies)
- LS 4.8 - T56 - Clutch setup - Mechanical / Hydraulic - Sachs1050 (21 replies)
- Dual disk Fidanza 33 lbs setup ok on street? (4 replies)
- 6.1l hemi manual trans help (0 replies)
- Cheapest Way to get Manual and Overdrive (3 replies)
- Mc Loed mid shift (1 replies)
- T56 Chevelle question (9 replies)
- LS7 clutch noise... (2 replies)
- Raising Trans Tunnel For T56 Magnum - W/ Pics (4 replies)
- Installing a CTS-V T56 behind a 5.3L truck engine (5 replies)
- Tremec magnum shifter (25 replies)
