View Full Version : Transmission crossmember ‘67 camaro TR6060
Bullrider
07-21-2019, 05:07 AM
I am building a ‘67 camaro with a LS3/TR6060 tranny and DSE subframe. Nobody makes a transmission crossmember for this application. I can fabricate my own, or buy a $300 Bowler crossmember for a T56 and modify it. The problem with fabricating my own is the trifecta of clearing the tunnel, making room for the exhaust and getting the right pinion angle of 2-3 degrees downward. Anyone else install a TR6060 in a 1st gen F body? Thanks.
thinkfastroth
07-21-2019, 10:42 AM
We built a 68 two or three years ago used a TCI suspension modified the crossmember from there kit and used the stock tr6060 trans bushing. I would suggest raising the entire trans tunnel 1in at a min from the fire wall to the rear bulkhead as the drive shaft can touch the top of the tunnel under compression.
minendrews68
07-21-2019, 01:10 PM
Take a look at what I did here: https://www.pro-touring.com/threads/117369-T-56-Early-Camaro-Trans-Swap?highlight=
Bullrider
07-22-2019, 03:17 AM
Did you have to modify the rear seat bottom cushion when you raised the entire tunnel? Does your crossmember allow for the exhaust to clear on each side? Thanks.
thinkfastroth
07-22-2019, 06:51 AM
When we did the swap we just raised the trans tunnel, we did not discover the drive shaft issue until after completion however it is only a slight touch but if I was to do it again I would have raised the entire tunnel. On the exhaust it clears just fine we ran a 2 1/2 with an h pipe the system is real close to what TCI used on the Camaro they originally built. If you pm me and get me your e-mail I'll send you some pics.
Z06vet
07-23-2019, 03:52 AM
I have used the G-force cross member in 2 cars w DSE subframe. It fits perfect, but you will have to use about a 1" shim under the trans mount to get the correct driveline angle. If you need any pics, let me know
Bullrider
07-24-2019, 06:39 PM
Did you use that G force with a TR6060 or was it a T56? If you have photos, that would be great. I did find a used crossmember that I can modify from Bowler that was designed for a T56.
Z06vet
07-25-2019, 10:03 AM
I have used it with both T56 (98-02) F body, and a magnum T56.
TheJDMan
07-30-2019, 10:30 AM
If you have to use a 1" spacer, it is not a perfect fit!
Z06vet
07-30-2019, 03:17 PM
I tried all off the shelf made crossmembers on my other car. The G force was by far the best option. Easy to install, clears the floor, nice exhaust clearance, and everything lines up nicely. I end up shimming the trans up on every build anyway. Even the new holley setup that in my black 69 has a small shim. I found it very helpful in fine tuning the angles for smooth highway operation. If I had the ability to fab up what DSE does in their shop, I'd definitely do it. Probably the only option to get it perfect. If there is another option, I'm not aware of it. What setup are you running Steve?
luvyab1ue
05-15-2020, 06:10 AM
Here are two low budget fab options. No they are not direct fit , but you could make it work and relativley cheap.
Rick's Camaro - Transmission Crossmember, 1967-1969https://static1.pt-content.com/images/pt/2020/05/331903711-1.jpg (https://www.rickscamaros.com/transmisson-crossmember-67-69.html#)
https://www.jegs.com/i/Trans-Dapt/969/6559/10002/-1
Save (https://www.pinterest.com/pin/create/button/?guid=MB2VrXuRWVxL-1&url=https%3A%2F%2Fwww.rickscamaros.com%2Ftransmiss on-crossmember-67-69.html&media=%2Fassets%2Frfg%2Fimages%2Fsize%2F750x750%2F sku%2F33-190371-1.jpg&description=Rick%27s%20Camaro%20-%20Transmission%20Crossmember%2C%201967-1969)
MORE VIEWS
https://static1.pt-content.com/images/pt/2020/05/331903711A1-1.jpg (https://www.rickscamaros.com/transmisson-crossmember-67-69.html#)
https://static1.pt-content.com/images/pt/2020/05/331903711A2-1.jpg (https://www.rickscamaros.com/transmisson-crossmember-67-69.html#)
Part #:
33-190371-1
Price:
$32.99 ea.
(No Discount / Limited Discount) https://static1.pt-content.com/images/pt/2020/05/helpicon-1.png
https://www.pro-touring.com/images/information-icon-icon.png No Discount/Limited Discount Part" data-ot="
Eckler's strives to offer competitive pricing on all of the parts we sell. In order to offer competitive prices, we have to limit or eliminate the discounts we provide on some parts. In addition, our agreements with some manufacturers prohibit us from discounting certain parts so they are not included in our promotions." data-ot-escape-title="false" data-ot-escape-content="false" style="margin: 0px; padding: 0px;">
https://static1.pt-content.com/images/pt/2020/05/truck-1.gif
GUARANTEED SAME DAY SHIPPING
Order by 2pm E.T. ships today (M-F)
andrewb70
05-15-2020, 07:54 AM
What about the Holley cross member?
mnr60
05-15-2020, 05:42 PM
I am using this cross member with a TR6060.
Not a direct bolt up to the transmission but only slight modification with a grinder and drill.
I am only in the build stage so I can't tell you if the driveline angles are correct yet.
https://www.holley.com/products/engine_swap_parts/ls_swap_systems/1968-74_gm_x-body_ls_swap_components/parts/12626HKR
billohio
05-30-2020, 06:21 PM
I am using a Hooker crossmember on a TR 6060. I was fighting it today and on a 68 camaro subframe. I could not get the crossmember far enough forward to use the front bolt in the factory subframe. I was either going to cut the center out of the mount so it could go closer to the front and not hit the transmission, or redrill one hole on each side. Theres 2 front holes on each side of my frame and I could get to the back front hole. The other is at least a quarter inch forward and there was no way it was going that far so I am drilling holes to let it sit on the rear front hole and the new hole will be for the back subframe hole. There was just no way it would work.
