View Full Version : Cooling
- Flex-a-Lite Flex-a-fit Radiators
- Best "Bang 4 the Buck" Radiator for my 55 ?
- custom shroud
- Cooling problem...any ideas?
- Mark VIII fan install questions?
- SBC short v long pump
- Did AFCO radiators pricing change?
- 2 1" cores or 2 1.25" cores???
- Catch Can v. Overflow tank ?
- Trouble finding rad hose
- can't find a lower rad hose
- Spal controller Mark VIII install question
- Ron Davis or U.S. Radiator?
- DC controller question
- 1st Gen LSX Cooling
- DC Controls kick-on temp
- Quick question, how do I remove clutch fan
- 71 Nova Cooling Issue
- Anyone use Durafix ???
- Spal fan controller and dual fans
- spal pwm power reset
- Ignition source for spal controller and Fans
- Mark VIII fan picture/info requested
- Jegs Aluminum LS1 radiator 67-9 Camaro
- LT1 accessory drive
- Ron Davis radiator fan switch problem
- SPAL PWM Fan Control Failed
- MK VIII 18 inch fan fit to 67 Camaro help.
- DC Controls contact info?
- spal temp sensor?
- Is this normal
- Ron Davis Radiator is Here - Quick Question...
- What to use for Flapper Door??
- Ebay aluminum rad
- interstate driving = overheating?
- Ron Davis Radiator and BBC fitment issues?
- DC fan controller or Spal PWM
- Electric radiator fans
- Temp sender?
- pulley setup
- Collapsing upper rad hose...
- Attn: Spal controller users?
- Piping
- Spal Controler Issue, All 3 Lights Flash
- Thin High CFM Electric Fans
- thermostat temp and switch temp
- Radiator recommendations/opinions
- factory 98-02 z28 radiator in a 69
- SBC W/P inlet dimensions
- DCC site DOA?
- Spal Controller and Taurus Fan
- water pump pulley vibration
- DC Control problem
- what can the spal pwm handle?
- need a new 98-02 ls1 fan shroud! broken in the box!
- Northern Radiator (Summit Brand) w/ Mark VIII fan
- Temperature Sensors on the heads??
- Radiator Cover
- 1969 Mustang Radiator
- Need New Cooling Fan Set Up
- coolant shcmutz
- Cooling, all aspects for hard use. kinda long, sorry.
- Leaking Water Pump
- Temperature Guage
- spal pwm controller isn't working
- DSE EraceR cooling fans??
- spal pwm and ls1 temp sensor
- Another Spal PWM control problem--please post!!
- anyone using EVANS NPG(+)
- Copper vs. Aluminum
- SPAL question
- looking for radiator hose (pic)
- DCC Fuel pump control kit
- Fan hangers for Afco?
- Taurus fan wiring
- Cooling Fan Need Help!!
- Additional Coolant Routing
- intake manifold rear water outlets
- How can I buy a fan from DC Controls?
- MARK VIII and SPAL PWM wiring question
- Allstar Aluminum Radiator?
- ebay aluminum radiator?
- Airflow and grille opening
- sbc overheating
- BBC Water Pump
- ron davis leaking
- Bypass Caps
- 1972 camaro radiator install issues
- Good pusher fan set-up - anything that works?
- LT1 cooling problems
- LT-1 Water pump on GEN I SBC?
- Pontiac 350 Cooling Issues
- Has anyone used a Autoloc/Zirgo fan?
- Water Pump Tension?
- stripped aluminum fitting - how do I get it out
- Anyone know how to wire a PSM Variflow?
- possible overheating problem
- spal pwm contoller issue.. solid red light
- LS1 remote water pump
- Tri-five radiator support
- Sensor Question??
- car is overheating
- Radiator hose hard tubing adapter
- Spal temp switch question
- Spal Temp switch question.........
- BBC, Griffin Radiator, Dual Spal 11's - Making it work..
- Cooling 540, need help!
- Which is quieter? Mark VIII or Taurus fan?
- Spal fans and Meziere water pump... Anyway to control both?
- Cooling and Plumbing
- Fan temp switch in radiator? Good idea or no?
- Multi temperature switch
- LT1 cooling system on your ride
- dc controller issue
- Radiator Hose Clamp for
- running hot
- How to get in touch with Brian Baskin?
- Is there a two Speed Mark VIII fan?
- Recognize these fans ?- take a look
- LT1 retrofit - Dexcool? Regular coolant?
- lsx radiator on old sbc??
- what im looking for
- Remote thermostat housing. Ever seen one or something like it?
- Brian Baskin, PLEASE help me !!
- Where can I get a radiator fitting like this?
- Oem electric fan
- DC Controls DRLA
- spal fan controler
- Coolant Temperature
- 94 LT1 temp gauge sensor
- Running Hot
- BBC hose from wp to maifold
- front runner heater hose
- alum rads w/elec fans or old school mech fan?
- trans cooler
- those 3/8 bungs on RPM air-gap...Again
- '67 Camaro Running Hot
- What coolant to run on a LS2/alum radiator setup?
- Which thermostat
- won't run cool
- Just finished my Mark VIII install. Soo much quieter
- DC Controls instruction sheet.
- coolant temp returning to engine?
- rad leak?
- Stewart components Fan
- Aluminum radiator
- trimmed taurus fan depth?
- dual fans vs. 1 large
- 99 Mustang overheating but no heat
- stupid ? on alum radiator
- Taurus Fan Positive Lead
- Which Radiator Cap??
- DIF Electric Fan Controller?
- Sacrificial Anode?
- Be Cool Universal radiator install
- OEM aluminum reverse rotation water pump??
- Reccomendation on a good radiator shop in LA?
- What water pump with OEM Serpentine System?
- How many amps do elect. fans draw ??
- electric vs. mechanical fans?
- AFCO LS1 conversion radiators
- Summit radiators?
- Radiator shroud design? need input for my build.
- Horsepower ratings on radiators?
- Radiator cover
- Radiator hoses
- AN radiator hose
- Just brain picker.
- Overflow Question
- Vintage Air??
- Proper eng. temp. for fans to come on??
- Another DCCONTROLS question!!
- Aluminium rad repair??
- Losing water
- Suggestions (warnings?) for custom radiator?
- Pulley sizes, temp gauge, water pump- hot 400 SB
- oil cooler mounting
- Advice for Aluminum Radiator w/Puller Fan Kit
- Beware of temp gauges, cheap ones
- water pump fitting
- electric fan question
- LS1 Radiator hoses with pics
- Mark VIII Fan Two Speed or Not?
- fan plugs
- Upper hose sucked shut.
- Where to install temp sending unit
- LS1 Radiator hose
- Anyone Used External Heat Exchanger Oil Coolers?
- mark 8 fans
- heating up on freeway
- ?on mounting taurus fanin G-body
- CONTROLLERS: What is currently best?
- Pusher puller?
- 68 Camaro 8 radiator comparison
- Mounting a transmission cooler
- Vintage Air Front Runner LSX
- Interesting oil/transmission cooler idea
- Spal fans - any to avoid?
- Chevelle Radiator LS1 with 4L60E ?
- Catch Can
- Radiator hoses
- Radiator drain plug
- Cross-flow or down-flow
- DCC wiring question ?
- Low Budget Radiator and Fans options (LS1 Swap)
- Electric Fan ID
- MARK VIII Fan
- need a billet radiator cap
- radiator issue! help
- Taurus fan wiring
- Mark VIII fan rubbing
- mark VIII Fan shroud
- camaro overheats with thermostat in but doesn't without thermostat
- Radiator pukin but not overheating
- 67 Camaro radiator/fan setup??
- HHR fan?
- Generic Jegs radiator.
- How to decode fan specs?
- Radiator and electric Fan setup
- OE vs. Aftermarket
- LT1 fans??
- Higher or lower degree thermostat?
- Started installing a fan assembly today...
- Mark VIII Relay System w/AC Feature
- Electric fan blowing its fuse
- Spal Controller vs. Taurus fan
- Cooling and Converter question...
- coolant leak!
- Blue radiator hoses
- Why the MarkVIII vs other fans?
- Bad thermo switch?
- double swicth coolant sender
- Need help keeping the wagon running cool.
- Anyone use Crown Victoria fan or radiator?
- functional '66 Chevelle SS hood inserts
- Electric Fans troubleshooting
- Ron Davis Dual Fan Radiator in Big Block Camaro.
- Radiator question
- Anyone Use Champion Radiators?
- Antifreeze?
- Entropytec radiators???
- Camaro Radiator Filler Plate
- 63 nova radiator?????
- New t-stat no work
- Im looking to order a new radiator.....
- Water Pump question, serpentine conversion
- Which is better???
- Temp fan switch location
- Radiator decision
- Clampless
