    Results 1 to 20 of 28
      Sep 2011
      Tacoma, WA
      Recaro Resource Guide
      RECARO RESOURCE GUIDE
      First off here is some basic Recaro knowledge, hopefully you guys will appreciate it. It mostly covers seats made from the late 70s and up, i dont have a ton of info on the earlier seats. I will update this thread as i have the time, still have ALOT to add.
      Most older Recaros have a basic model number such as LX, LS, SRD. For most of the older models the first 2 letters stand for the back of the seat and the last digit stands for the base of the seat. For example an LX will stand for the back of the seat with its trademark pointy triangular bolsters but an LX-A will be the same back mounted to a flat base. Here is an example of a 3rd gen LX (top picture) and a 3rd gen LX-A (bottom)
      Here is an original brochure showing model names for ref. and pdf link if interested in higher res
      https://docs.google.com/viewer?a=v&p...MzdkZWFi&hl=en
      Most of the common recaro seats can be traced through 4+ generations, each with their own specific details and differences. For example the first few generations of LS's (also known as the idealseat) have the trademark large rolling D shaped upper bolsters with lower bolsters that are very large and slope very close to the back of the lower frame. The original idealseat also had an upper adjustment knob. Later generations have a very similar back at first glance but the lower bolster foam is much smaller with the slope of the bolster midway back on the frame as seen here. The first 3 generations all had different back adjustment knobs and covers as well.
      early vs newer foam
      The construction of the early recaros was very primitive compared to the later generations. Honestly the biggest improvement i have found through the generations is the advancement in the construction of the seats. The gen 1/2 seats are fairly difficult to assemble where as the later 3rd and 4th generations are about as simple as you can imagine. The newer seats such as the sportster cs, trend, sport, and so on have actually become a completely different monster, recaro pretty much redesigned the basic construction of the model line in the 2000's.
      How to spot a FAKE
      Its not always easy to spot a fake but there are a few simple steps you can follow to increase your chances of purchasing a genuine recaro. My best advice is just to do your research ahead of time. If you are going to check out a set of seats on craigslist look up pictures of real seats or maybe even print out pictures to bring with you for reference. In most case if its too good to be true it normally is. This is also mainly only a problem with a handful of models including the srd/speed and the line of fixed back recaros. Here are a few things to keep an eye out for..
      - Is the 'RECARO' lettered correctly? If the letters are spaced from each other? Is the lettering crooked? If it generally looks off chances are you are not dealing with a genuine recaro.
      - If it is a fixed back does it have a valid FIA tag? All recaro fixed back seats will have a real fia visible on the side of the seat.
      - What style diaphragm does the seat use? You will only find 3 style of supports on genuine recaro seats. The first design was a support strap. They were made of a nylon style material and each seat would have had around 3 of them going horizontally across the base attaching with a U style hook. The second generation used a support diaphragm. It was a single support made with 1-2 large rubber pcs bonded to a burlap style material and attached using a dowel and hook method on each side of the support. ALL srds used a 1pc diaphragm. The newest Recaro seats use a molded plastic but that is pretty self explanatory. Here are a few examples..
      • gen 1 straps (New jjcustominterior strap on top, original in middle)
      • gen 2 diaphragm
      • FAKE speed as found on ebay (you can also see the material is hog ringed onto the frame, something recaro hasnt done since the 70's.) Honestly there are about 100 things i could pick apart on these seats to show they are fake but this is the easiest to spot. They dont always look like this but this is the most obvious to spot.
      Here is another speed that at first glance looked 100% legit short of some "off" recaro stitching but once i removed the insert found this..
      If you are going to purchase a seat and want to send me pictures of it ahead of time im always more then willing to help and identify anything that i can.
      Seats
      • Model C (classic c / ortho / classic c / cse)
      (Est. $400 - $2500 per set depending on specific model / options / condition)
      Available in power and manual variations as an aftermarket seat and dealer option for various european cars. Most featured 8 way adjustable bolsters, heated inserts, power air controlled lumbar support, and some also had a blatpunk speaker headrest. The Model c was Recaros top of the line luxory seat offered in the 80's and through the 90's. Variations of this seat were optional in e30 bmw's (6k dealer option) Mercedes 190 cosworths, Audi URQuattors (non power), Various Porches, and a few other vehicles that escape me at this time. Variations of this seat are still available from Recaro as the Ortho line.
      These seats were also available in a few manual versions that used the B style base.
      • LS
      (est. $300-$2000 depending on specific model and condition)
      The LS is one of the most popular seats Recaro made through the late 70's/80's/90's. Variations of the LS were found in but not limited to cars made by Ferrari, BMW, Alfa, Volkswagen, Porsche, Ford, and more.. They are most commonly found in mk2 volkswagens and Alfa Romeo milano verdes within the US.
      The later ls was available with an a,b,c, or d base, but most commonly found with a b or c base. There are also a few rare power version that i do not have a ton of information on. (pictured below in black with control panel on bolster)
      • Speed / SRD
      (est. $300-2000+ depending on model and condition)
      By far the most copied Recaro of all time. Be very cautious when buying these seats as prob 80% of the seats on the market are fake chinese replicas. I would not feel safe putting the replicas in a car as the build quality and materials used are fairly poor (i have litterally seen people shred the metal on the base just removing sliders (can post pics of carnage). The Recaro SRD is prob. the most well known Recaro as it has been available since the 80's and is still in production to this day as the speed. They have came in everything from e30 bmw's to Toyota supras along with hondas, nissans, fords, and so on..
      Also here is an easy way to tell the difference between a speed and an srd. Take a close look at the curves of the upper bolster foam.. The SRD has a larger more triangular "shoulder" foam where the speed is smaller and more smooth. Also you can see the speed has a larger headrest section but the ITR versions of the seat were actually a hybrid of the two and tech a speed. Also NO TRUE SRD ever came with the small recaro logo, only the speeds.
      speed
      srd..
      Used to be known as a2coupe2a
      Sep 2011
      Tacoma, WA
      • LX/SE/Specialist
      (est. $300-$1500 depending on specific model and condition)
      The recaro LX is one of the oldest recaro variations available along with the LS. The Recaro lx still has a variation in production to this day(specialist). It is commonly found in early to late 80's cars such as the TransAm, Mustang, 300zx, and various other models. The Gen 1 lx has the larger lower bolsters but maintains the same triangular back that is the trademark of the LX.
      Another member of the LX/LS/etc family that's often seen, the SE. These were Recaro's "budget" sport seat in the late '90s and early '00s, they also had a decent period-correct look for '70s and '80s cars since they were mostly based on the LX.
      • A8 (gen 1/2)
      (est. $600-$3k depending on specific gen, condition, and trim)
      The A8 is by far one of the most highly desired recaros available at this time. They are one of the first recaro sport seats to feature a new frame design for passenger vehicles. There were 2 variations of the A8 to be released and they were available as factory options in a select group of exotics. The majority of A8's you will find are of the aftermarket variety.
      Gen 1
      Gen 2
      General Info
      mounting pattern
      available headrest options
      *Netted*
      *Standard Solid*
      *Wrap around*
      *Wrap around w/speakers*
      Sep 2011
      Tacoma, WA
      Seat Dimensions
      Brochures / Ads
      • Audi
      • Volkswagen (mk2)
      Here you can see that VW offered the Model C, LX, and LS as optional seats for the mk2's in europe.
      • Ads
      Sep 2011
      Tacoma, WA
      Sep 2011
      Tacoma, WA
      Crash Test
      Recaro SRD:
      Bride Brix:
      Sep 2011
      Tacoma, WA
      still have a ton of info to add and more seats to list, if you guys ever have any recaro related questions feel free to let me know.
      I restore them up for a living and have nearly 100 seats so chances are if you have a question i have an answer.
      Ron is a wealth of knowledge when it comes to Recaro seats old and new.
      Sep 2011
      Tacoma, WA
      ty - they pretty much consume my life at this point haha
      Portland, OR
      Quote Originally Posted by jeff70 View Post
      +1 on that.
      I learned an enormous amount on Recaros and what to look for from Ron when I bought my SRDs though him.
      Kevin
      Coronado, CA
      You forgot all about the kid's ProSPORT seat. It was the only Recaro seat I ever owned, well, I guess my daughter owned it. Truly, an expertly designed seat. I read somewhere that it is the seat that has the most developement ever from Recaro.
      Johnny C.
      Sep 2011
      Tacoma, WA
      wow didnt know you were here too, looks like ive been missing out. How is that bolster holding up? Did it go back into shape or is it still wanting to sit crooked?
      Sep 2011
      Tacoma, WA
      Quote Originally Posted by go-fish View Post
      Yeah i know they put a ton of time into the kids seats. They pretty much came out an were able to dominate nearly everything else on the market. You figure Recaro has been so far ahead of the curve for so long that they have a huge backlog of research to build off of. Its a shame that the quality has went down with the newer seats.
      They were just sold 8 months or so ago to johnson controls, hopefully they wont take them in the wrong direction.
      Portland, OR
      Its in about the same position. I tried to ease it back when I got back but couldn't quite get it to stay. But I didn't try very hard.
      Kevin
      Sep 2011
      Tacoma, WA
      Well lmk if you cant get it and maybe i can strip it down really quick and adjust it for you. I should be down that way in the next month some time.
      Oh and btw, just recovered another set recently. Still an option if you ever want to go down that road
      May 2007
      Mooresville, Indiana
      Wow, that is a ton of information on Recaro seats. Someday I would love to own a set! Thanks for all the work you put into making us all smarter.
      Tom
      Sep 2011
      Tacoma, WA
      No problem, still have a ton to add just need more free time to do it. Hopefully you guys will find it useful
      Sep 2011
      Tacoma, WA
      Going to try to get some updates on here tonight
      Sep 2011
      Tacoma, WA
      If you guys have any special request or questions feel free to lmk and ill help any way i can
      Ron,
      What model seat is the one just above in black leather? Also do you have them available and are what is the cost?
      Chad
      Sep 2011
      Tacoma, WA
      That would be a Recaro SRD that we recovered and installed a custom anti sub guide in. They start at $1800 for a set.
