    Results 1 to 20 of 81
    Thread: Led Headlights
      Jun 2010
      Commerce MI
      Led Headlights
      Saw the Stabil 71 Camaro on Car fix the other night. Interesting front end design, but sweet headlights.
      Has anyone used these and what would need to be done to make these work in a 67 camaro.
      A buddy of mine just put these in his Jeep and they are very nice quality and throw light big time!
      Thoughts
      When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance
      -Excellent option for light, medium and heavy-duty trucks, off-road vehicles, classic cars, motorcycles and more.
      -Metalized reflector optics provide a lighting experience that smooth and clean across the driving surface
      -Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
      -Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration
      -Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards
      -Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture
      -Advanced circuitry protects against voltage spikes up to 600v
      -Drop-in replacement for #6014, 6015, 6016, H6024 and Par 56 headlamp designs
      -Uses standard, H4, 3-blade wiring connector
      -Equipped with Truck-Lite 3-Year Limited Warranty.
      7'' Round LED Headlamp, Complex Reflector Optics Design
      Material:
      Hard-coated polycarbonate lens
      eCoat aluminum housing and internal structures
      Metalized Reflector
      16 Gauge Wire
      Light Source:
      2 LED Arrays
      9v-33v Multi-volt design works with both
      12v and 24v systems
      Designed At:
      12.8v, 1.80a (low beam), 3.60 amps (high beam)
      25.6v, 1.00a (low beam), 1.80 amps (high beam)
      1,300 Lumens
      Additional Specifications:
      Operating temperature range: -40˚C to 50˚C
      Overvoltage protection to 600v, w/constant output
      Mechanical aim
      NOTE:
      Fits all Jeep's with 7" Round Headlights
      Truck-Lite is now offering a Pulse Width Modulation (pwm) Adapter Harness that eliminates headlight flicker in 2007- present Jeep® JK models. This H13 to H4 adapter will store power during "on" time which allows the lamp to utilize constant “on” energy thus eliminating the flicker.
      Mar 2014
      Long Beach
      AH yes the Truck lite 27270c... As made famous by the Mark Stielow mayhem camaro.
      I have them in my 1969. No modification required. Direct replacement.
      i just took out the old headlight and replaced it with the trucklite housing. the only thing of note is that edge on the cast aluminum housing where the stock bracket sits is a little deeper so the headlights "stick out" past the trim rim a little..maybe 1/4 inch. Once they're both in you cant tell
      I dont run that resistor and have no flickering. Just plug the trucklite plug directly into the stock plug.
      These are super nice units. build quality is excellent and light out put is on par with my GFs nissan leaf which has OEM LED headlights. Not to mention they look cool as #@&$..i smile every time I turn them on..Got mine on Ebay for $350 for the pair..worth every penny just for the safety of actually being able to see
      Apr 2012
      Woodstock, IL
      Led Headlights
      We've used them in several builds and have been happy. They do require a bit of modification to the inner bucket or outer rim, so they're not a 5 minute replacement like the stock ones.
      They work really well though!
      -Dale
      SchwartzPerformance
      Apr 2010
      Pittsburgh, PA
      Check out
      Www.jwspeaker.com
      72 buick skylark
      May 2010
      kitchener,Ontario,Canada
      5 3/4" for us cool kids with the Chevelles
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Newbury Park, CA
      Quote Originally Posted by Nothingface5384 View Post
      One of the best practical additions that the Camaro has received. James Shipka, Jimi Day, and I had other drivers following us at night during OLoA since we literally lit up the whole road with the JW lights. Roger at Ironworks carries them and are worth every penny.
      It looks like they have 5-3/4" versions now, and like the 7", bucket mods are needed.
      More info here https://www.pro-touring.com/threads/...t=honor+flight
      Jun 2010
      Commerce MI
      Thanks guys for your feedback! When you say bucket mods, can you be more specific? I am guessing that the hole in the back of the bucket needs to be enlarged so the back of the new light fixture fits properly?
      Jacksonville, FL
      When running these LED headlights, are relays needed?
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Sep 2011
      Southern Ontario
      I'm from Ontario, and I bought mine from Traction.[they supply equipment to big truck industry, open to the public] Mine cost $185 Canadian each, so not a bad deal with your dollar.
      Aug 2002
      Sweden
      Country Flag: Sweden
      Anyone have a picture of illumination geometry (or whatever it's called)?
      this;
      Feb 2007
      Tinley Park, IL
      I think "cut off" is the term you're looking for.
      Nick ~
      1969 Cutlass
      Jan 2009
      Huntington Beach CA
      Those lights are on my shopping list. As soon as the car runs and actually needs headlights I'm on it!
      Apr 2010
      Pittsburgh, PA
      I'm Tempted to get 4 Hi/low versions of the Model 8630s
      72 buick skylark
      Mar 2014
      Long Beach
      As far as fitment....The back of the trucklites is round as opposed to the JWs which stepped, so it fits inside adjustment bracket pretty snuggly. I think the only thing that trimming the bracket would do is sink the housing in the hole more more. If you look at my pic ypu csan see the lights stick out of the trim rim about 1/2" as opposed to being flush. I didnt think it was worth messing with...Once you tighten down the lock ring, the headlights arent going anywhere
      Also im my opinion the JWs are kinda ugly and too "obvious"..Plus in the pic the light out put looks blue..Might just be the camera..The light out put on the truck lites is kinda purpleish like OEM HIDS/LEDS
      Ill try and get a pic tonight if i remember
      Aug 2002
      Sweden
      Quote Originally Posted by Mr Nick View Post
      Yes, that was it. Thanks.
      Any pics of the cut off?
      Mar 2014
      Long Beach
      No relay. I just plugged it in the stock harness
      From what I read the relay is supposed to prevent flickering in late model jeeps
      Mar 2014
      Long Beach
      cutoff
      Appleton WI
      where did you buy your lights, Decline? I tried looking for "Ironworks" and had no luck with anything related to lighting.
      Jim
      Fredericksburg, VA.
      I installed a pair and they fit the 68 buckets and rings with NO modifications. I have heard that there could be problems clearing the RS headlight doors They also needed NO relay. Simple plug and go.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jacksonville, FL
      You can pick them up on EBay for $338 shipped (pair).
      Chris
