    Page 1 of 8 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 142
      Jul 2009
      South Orange County
      So who makes a tasteful, practical tow hook setup
      Front of the car---69 Camaro---any pics or suggestions? Looking for a clean install, where you got the part, etc-----Sounds like the track I am headed out too is a bit strict on this part so it's time to make the jump and make it a real race car---
      Doug
      Lawrenceburg, TN
      Quote Originally Posted by DFRESH View Post
      Doug
      its still a peg leg, LOL
      mine too
      I'm also looking for nice looking tow hooks
      Huntington Beach, CA
      Doug,
      It's self tech and the first time I ran with SV I had no tow hook. That said I got a pretty sweet tow hook prototype from Mr. Quick aka Vince on here. Not sure what he has for the 69 but for the 67/68 it's pretty slick. Its a two piece unit and the hook itself can be removed/installed with no tools.
      Jul 2009
      South Orange County
      Quote Originally Posted by Chad-1stGen View Post
      Doug,
      Ok---will see if I can track down and PM the guy.
      D
      Jul 2009
      South Orange County
      mine too
      I'm afraid so---team OLJ still running one hot.
      pro-touring
      Suisun City, Ca.
      Anybody have any pictures of Vince's tow hook? Would like to see it.
      Mike
      So here is an earlier prototype of Vince's hook. I understand he has improved the design since. I haven't yet cleaned all the bugs and road debris from my last track day off the car... don't think less of me ha ha ha
      Jul 2009
      South Orange County
      Man, that is a clean setup--very nice.
      May 2002
      Northern California
      thanks guys, the new hook has a round edge to it and a smaller diameter to clear the bumper when you spin it off. Working on the rear receiver for it too. One hook and two receiver brackets. You can buy one or front and rear.
      These should be available in May.
      vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      welded to the inner bumper extension. Just a reinforced nut, then screw in a ricer tow hook. Used it 3 times, holds up fine.
      Jul 2003
      Anaheim Hills, CA
      This is something I need to do... I have an aftermarket frame so I need to make something.
      Ricer hook looks good.. I wonder how strong?
      I heard some sanctioning bodies want it to be able to support up to 5,000 lbs.. yikes
      1968 Track Rat Camaro:
      Jul 2003
      Anaheim Hills, CA
      vince
      I have no bumper.. send me one of your "too large" rejects! lol
      I was thinking of making one using one of these.. a plate and a threaded sleeve the right length should do the trick. Should be strong enough:
      http://stuttgartperformance.rpmware..../i-398559.aspx
      or
      http://www.saferacer.com/rennline-po...productid=2124
      The bracket should be pretty easy... the rear hook is the hard one without cutting a slot in the rear panel like on the OLC car.
      Jun 2009
      There is a company that makes soft tow straps. You can zip tie them out of view, and if you plow it into the weeds, it comes out.
      http://www.ioportracing.com/Merchant...egory_Code=TOW
      Dan W
      1968 Plymouth Road Runner
      1962 Dodge Dart 440
      san diego
      Here is the one we run on the 65 mustang
      I use it all the time to pull the car on the trailer.
      had a request to take a pic with the tow hook removed. Removed you can't see anything different on the car.
      Happened to drive the car to work today so here is a quick vid of the tow hook on the car and removing it. I tend to leave it on the car otherwise I'd probably lose it in my black hole garage ha ha
      Dec 2009
      That's too easy...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      pro-touring
      Scottsdale, AZ
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Jun 2006
      TX
      Quote Originally Posted by Cdog View Post
      I bought 2 Rennlines.
      That hook looks great. I might have to pick one up.
      Kyle
