Results 1 to 8 of 8
Thread: 200R4 or 700R4?
10-23-2022 #1
200R4 or 700R4?
Which is the better transmission? I’ve heard that the 200R is basically a turbo 350 with and overdrive and the 700R is a 400 turbo with an overdrive, true?
11-10-2022 #2Registered User- Join Date
- Sep 2007
- 424
The 700-r4 is sorta like a turbo 350 with a 4th overdrive gear added. Also called a "4L60E" when it's electronic.
The 200-4r (not r4) is another 4spd overdrive but it's a different deal. Smaller case, different gear ratios, etc.
The 700-r4 can be beefed up with money (almost anything can) but it's basically a mediocre item. A stock one is good enough to use in street cars, but high-performance use will break it.
The 200 is weak from the factory but it responds very well to aftermarket work. I've heard it argued that if you were gonna spend several thousand bucks on either one, the 200 would be the better end result even though it's probably weaker to begin with.
If you want a 4spd overdrive version of of an old turbo-400, that's the 4L80 series. It's a whole notch bigger (and heavier) than any of these others.
11-11-2022 #3
