    Page 6 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 16 ... LastLast
    Results 101 to 120 of 584
    1. #101
      Jun 2012
      Chicago burbs
      Oh man, I am such a fan of your project! Just seeing what you've done with an 18x8 garage...imagine if you had an 18x10!!! You have great taste and a helluva vision for bringing a project together. Your car would be bananas anywhere in america, I can't imagine how crazy it must be driving it around France(I know I'd give it more attention than a lambo for sure). Thanks for all the pics, would love a video if you get a chance!
      1969 442 6.0L LQ9 T56
      Fab9 w/ custom 3 Link conversion
      FAYS2 Watts link
      Thanks to Mark at SC&C for his honesty and passion for the sport, and Ron Sutton for the wealth of knowledge that has helped shape so many of the cars on this site.
    2. #102
      Oct 2016
      thanks a lot man ! yes I'd like to work in a bigger garage with all stuff to work easier. I will make some videos when the car will be finished
      my goal now is a 900-1000hp low boost street car, every luxury cars are now over 700hp, it's so easy to make big power now. I think 1000 is a good number, more than enough to eat porches, lambo, ferrari....etc but without buying ultra expensive parts
    3. #103
      Oct 2016
    4. #104
      Oct 2016
      tubings inside the trunk done, there will be 2 weldings like the main tubing, this one is the first still at 60amp
      I spend a lot of time cause I've no tube notcher, it's ok but not perfect
    5. #105
      Nice.
    6. #106
      Oct 2016
      thanks Wayne !
    7. #107
      Oct 2016
      here some pics how I will go to the firewall for the 6th point of the rol cage
    8. #108
      Oct 2016
      there will be some brackets, I will not weld the tubings directly on the firewall
    9. #109
      Oct 2016
      some good news today, a friend with his 1300hp awd chevelle will sell his Dart Littel M bloc, all forged internal, a compression ratio of 9.7:1. The solid-roller camshaft 255/262 degrees of duration at .050-inch lift, a prted Edelbrock Victor Jr. heads which now flow 310 c.f.m.
      I will run it at 15psi of boost and see what happened, I hope around 900-1000hp and buy a other thrid member with 35 spline wavetrac differential
    10. #110
      Oct 2016
    11. #111
      Aug 2010
      Seattle area
      Very nice work .Nice attention to detail .I have a 1979 Z-28 RS .With a 377 cubic inc weiand 142 mini blowe small block .Chevy
    12. #112
      Oct 2016
      thanks a lot Zspoiler
    13. #113
      Oct 2016
      roll cage almost finished, all brakets are welded everywhere I was able to weld, the car is really stiff now ! I can't wait to test it on the road ! and I've oredred some parts and a new wavetrac differential carrier but this time with 300M material 35/33 spline axle shafts from Dutchmann
    14. #114
      Oct 2016
    15. #115
      Jun 2011
      St. George, Utah
      Great progress and congrats on the write up!!
      SRD on Facebook
      79 Cutlass wagon build
    16. #116
      Oct 2016
      thanks a lot !
    17. #117
      Oct 2016
    18. #118
      Oct 2016
      ordered today
    19. #119
      Oct 2016
      Finaly I've found some room to fit tubings from the firewal to the front subframe, driver side and passenger side tubes are different cause I can't bend them with the same angle because of the intercooler pipes but they fall approximatly at the same location on the subframe
      I've ordered all needed to build a custom 3-piece splined sway bar and receveid today my new seats
      I will use a 1.37" with 1-3/4 48 spline nascar sway bar from Speedway Engineering rated at 558 lbs at 15" ( about the same spring rate as the Speedtech 1 piece sway bar ) with custom bend arms
      http://1speedway.com/index.php?route...&product_id=88
      https://www.ebay.com/itm/CUSTOM-DELR...-/192461083932
      https://www.onlinemetals.com/merchan...=2&top_cat=197
    20. #120
      Oct 2016
