    Page 12 of 30 FirstFirst ... 2 7 8 9 10 11 12 13 14 15 16 17 22 ... LastLast
    Results 221 to 240 of 593
    1. #221
      McKinney, TX
      It would be recommended but I went off pre-determined measurements for the axle and hoped the wheels fit. Luckily my redneck measurements paid off. Hurray for firsts!!
      89 Mustang "Box Wine"
    2. #222
      Mar 2013
      Beaufort,SC
      Love your build you making think I should do rear frame rails on my Nova when I do the mini tub.
    3. #223
      Dallas, TX
      well I guess luck was on your side then. good job.
      I meant to take you up on the offer to come up and check it out, I just couldn't find the time. maybe when my daughter's soccer season starts back up in July I'll find the time. that is, if the offer still stands, of course.
    4. #224
      McKinney, TX
      Not much to see but a few beers can be had, come on!
      Hell ya, cut up the Nova! Step outside the box.
    5. #225
      Dallas, TX
      sounds like a plan! I'll be in touch. I'm mostly interested in your mini-tub work.
    6. #226
      Roanoke (FortWorth) Texas
      Looks great. I was going to compliment your welding progress until you mentioned someone else did the work. LOL. Glad your back at it. Keep it going.
      Chris
      Total Cost Involved - Ridetech - Fatman - Total Control Products - Gateway Performance - MaverickMan Carbon
    7. #227
      Birmingham, AL
      The new wheels and tires look great. I like the spoiler and where you are going with the taillights too. If you don't mind me asking, can you share how much you have in the 8.8 swap. Is it an Explorer setup? I am really thinking about using one of these with Big-bearing ends and centering up the pinion. Where did you source the axles from or did you have the existing ones shortened and re-splined? You have to get some bearings pressed on too for the BBF ends right?
      Stephen
    8. #228
      McKinney, TX
      I picked up the explorer rear for $175 at the junk yard. 3.73's, 31 spline, trac loc, disks. Lowfast gave me new backing plates and a short side axle. I had a local shop cut the long tube down to the length to fit the other short axle for $160. So 2 stock right side axles and a cut down tube. I'm using the stock axle ends, they're plenty strong. I believe Lowfast is running 9" brakes on his explorer 8.8 with the stock 8.8 tube ends.
    9. #229
      Birmingham, AL
      Do you remember the width running the axles you are running?
      Stephen
    10. #230
      Texan Back in Texas!
      Yep, 12" Wilwoods w/ D154 caliper meant for big bearing 9" ends, bolted right up.
      1965 Falcon Hardtop
    11. #231
      Birmingham, AL
      I wonder if Tobin's c6 brackets would work. He makes one for Big bearing ends.
      Stephen
    12. #232
      McKinney, TX
      Quote Originally Posted by srh3trinity View Post
      I believe it's close to the stock 8" width. Whatever an Explorer rear is minus 3".
    13. #233
      Feb 2011
      Indpls, IN
      My Explorer 8.8 with 3" removed is, From wheel mounting point to wheel mounting point its 56.5" may be off a little.
    14. #234
      May 2004
      Dallas, TX
      OK..I am getting a real bad case of the mini-tub fever
      PROGRESS!!!!
      8.8 is narrowed
      new wheels fit perfect
      Its sitting on jackstands due to lack of axle bearings, I'll get those soon so I can roll it outside.
    15. #235
      McKinney, TX
      I took the duck tail off and stuck all the stock pieces back on. It cleaned it up a bit IMO so it may stay like this.
      Better view of wheels and tires.
    16. #236
      Jun 2009
      Spring, Texas
      Leave the Duck Tail!!!!
      It gives it an air of Bad Assness
    17. #237
      Quote Originally Posted by 69*Goat View Post
      I agree with Goat. Either that or street fighter style chin and decklid spoiler.
      http://www.jakesrodshop.com/public_h...t_spoiler.html
      Like this one but only on the decklid not to extend over the rear corners.
      Chris
    18. #238
      McKinney, TX
      Question: for leaf spring sliders, do I get the Chrysler style or Camaro style? Also, does anyone have suggestions besides the Afco roller bearing sliders?
    19. #239
      Apr 2013
      Granite Bay, CA NORCAL
      Nice job on the fab work so far. Makes me want to get back to work on my S10. Since I moved I don't have a shop but hopefully I will fix that soon. I also picked up a 72 Nova and started a thread on it here. I love the Camaro tail lights by the way. Let haters hate.
    20. #240
      Nov 2011
      Tampa, Florida
      I didn't even know what a slider was till I read your post. I read another post where the guy compared Afco and CMS. They were pretty close. Afco housing was better but CMS had better hardware. Speedy had the afco for 83.00 but just saw amazon had it for 11.00 bucks?Pretty cheap. But 15 lbs.
      Hers that link http://www.timskelton.com/lightning/.../leaf_mods.htm
