    Page 2 of 2 FirstFirst 1 2
    Results 21 to 24 of 24
    1. #21
      Nov 2011
      70 chevelle lower a arm dimensions
      In addition for the bushing hole diameter, what point did you measure to from the centerline of bushing to the ball joint seat to get the 4.875"? Was it to the "center" of the ball joint seat or to the nearest edge of the opening where the ball joint goes?
      And do you have a measurement for the location of the spring perch?
      Lastly, here are my layouts on CAD. These look good?
      Name:  Screen Shot 2020-05-16 at 3.32.12 PM.jpg
Size:  5.0 KBName:  Screen Shot 2020-05-16 at 3.32.54 PM.jpg
      Doug
      1970 chevelle, carb'd, turbo'd 383ci with a tremec tko.
    2. #22
      Nov 2011
      OK so I can't figure out how to enlarge the photos. I just emailed them to you Scott.
    3. #23
      Jun 2012
      Chicago burbs
      Quote Originally Posted by dug View Post
      4.875 was the center of bushing to center of bj.
      The bushings are still in the stock arms , if you need I can press one out, but the better option may be to measure a new bushing and then the hole will be a few thousandths less for a light press.
      Definitely need the spring perch location,will grab that tomorrow during the rainstorm.
      1969 442 6.0L LQ9 T56
      Fab9 w/ custom 3 Link conversion
      FAYS2 Watts link
      Thanks to Mark at SC&C for his honesty and passion for the sport, and Ron Sutton for the wealth of knowledge that has helped shape so many of the cars on this site.
    4. #24
      Nov 2011
      Quote Originally Posted by jetmech442 View Post
      Ok, my drawing didn't clearly show the BJ. There is a line that is at an angle and it measures 1.99" which would represent the BJ. Does that make sense? And is this correct?
      Doug
