    Page 1 of 8 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 144
      Nov 2012
      '67 Mustang Coupe
      Hello all. Here's some info and pics from my latest project. She's a '67 Mustang coupe that I rescued from a family in Merced, CA. The car is an original California car, San Jose built, C-Code V8/auto car, no rust, no damage anywhere, original black and yellow plates, and said to be a "grandma car" most of its life. The car was mostly original aside from aftermarket wheels and tires (which immediately found their way onto my little parts-go-getter truck), a 5.0 roller longblock conversion (had to redo it as it was done wrong as usual), aftermarket stereo, and of course a cute little feather hanging from the rear-view mirror.
      I realized grandma never put the car out in the rain because the first day I did, the original paint literally washed right off the driver's front fender over night. So next came an unplanned paint job and stripes, and some minor body work along the way. ..and of course with paint comes a huge list of other little things that just need to get done.
      The stock 5.0 engine needed a little "pick me up" so I changed that up a bit, ...ported 1970 closed-chamber heads by the geniuses at "Power Heads, E-cam and 1.7 roller rockers, port matched Torker intake, Quick-Fuel SS-650-AN carb, MSD ignition and dizzy. It all woke this sleeping beauty up! She makes impressive power for such a basic engine setup and to-date she runs a very impressive 12.93 1/4 mile on radial road-race tires.
      The interior was already reupholstered for the most part by the previous owner so it got a little cleanup, a new headliner, Custom Auto Sound kick-panels, and a used Grant steering wheel that fits the bill for now. (Has since been changed to a Moto-Lita leather wheel, dash panels and pad have been replaced with new, kick panels, stereo and speakers have been added)
      I've added 4-wheel 12.19" Wilwood brakes, narrowed 9" truck rear with 3.25" axle tubes, 3.73 gears and a nodular thirdmember, 31-spline Currie axles, under-rider "Traction Master" traction bars, Maier Racing adjustable rear panhard setup, Global West subframe connectors, complete Total Control front suspension and their R&P steering (I ordered every upgrade TCP had), adjustable coilovers up front and 2-way adjustable Varishocks on all 4 corners, and the list goes on...
      Now on to the pics!.... (A FEW OF THESE PICS ARE FROM THE MOCK-UP AND EARLY TEST STAGES SO IF YOU SEE SOMETHING TACKY I'VE PROBABLY FIXED IT!)
      BEFORE
      AFTER
      ENGINE BEFORE
      AFTER
      INTERIOR BEFORE
      AFTER
      MORE SUSPENSION
      UNDERCARRIAGE AND EXHAUST AFTER
      Thanks in advance for your thoughts and comments. I have a ton more "in progress" pics as well.
      TCP front coilovers with double adjustable shocks and manual rack&pinion + 12.19" Wilwoods
      AUTOCROSS AND 1/4 MILE DRAG VIDEOS AND TIME SLIPS
      http://www.youtube.com/watch?v=uqWBb...ature=youtu.be
      http://s69.photobucket.com/user/bwke...42ee6.mp4.html
      http://s69.photobucket.com/user/bwke...7be1f.mp4.html
      http://s69.photobucket.com/user/bwke...564d8.mp4.html
      Nov 2010
      Wharton, Tx
      Looks nice!
      Sydney, Australia
      Country Flag: Australia
      Really nice work!
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      Nov 2012
      <<<<Thanks guys!
      Here is the build-up on the rearend....
      9" swap from truck to Mustang.
      The truck 9" housing needed to be narrowed to Mustang specs (less 1/2 in my case) and had Big Bearing "Strange" axle ends welded onto it, using a jig for straightness. The old spring perche(s) from the truck were plasma-cut off then ground flush with the housing. Next I needed to weld on the new spring perches for the Mustang. ...(VERY IMPORTANT NOT TO GET TOP AND BOTTOM MIXED UP AS THE TRUCK HOUSING ORIGINALLY HAD THE PERCHES ON THE TOP SINCE THE LEAFS ARE "OVER" THE REAR INSTEAD OF BELOW) The 9" and 8" rears have a short and a long axle, make sure these are on the correct side of the car when welding everything up.
      The new leaf spring perches were measured out on the tubes at 43" center to center and just marked for now. We need to set the pinion angle to factory specs BEFORE tacking and welding them up.
      Using a LEVEL table I mocked the housing up on some axle blocks I had in the shop. I used a magnetic angle finder and set the axle housing to 5-degrees UP. ..This is the factory angle for most Ford cars (if not darn near all), including Mustangs in the 60's.
      Once I tried the angle finder in numerous places and was SURE the angle was right I tack-welded the pads on.
      Now it's time to weld it all up. I welded one side of each perch, and alternated back and forth from tube to tube as not to overheat and bend the tubes. And Viola! ..Perches are installed.
      Coming soon are the new axles and tapered bearings, fitting up the Wilwood discs, and making/mounting the rear brake lines to the housing.
      HOUSING: Ready and patiently awaiting axles and gears
      If all of my measurements came out right the axles should slip right into the carrier. (crossing my fingers!)
      Mocked up the brakes and everything looks good there.
      THESE AXLES ARE REALLY ROBUST! They start out HUGE on the bearing end and taper down very gradually to the 31-spline ends. NICE, I LIKE! Good 'ol "Currie", they make some nice axles.
      I had to have an access "window" /hole cut into the axle flanges so I can get to my bearing retainer bolts! (most factory axles have this already)
      So the axles are at the machine shop for another day or so.
      I told Currie when I ordered them that I would be running Wilwood brakes and according to popular belief they were supposed to ask me about this? Apparently it's super common with the Wilwood parking brake assembly to need the access window. Otherwise there is NO WAY IN HELL to get to the nuts to tighten the backing plates.
      Part of my problem also is that the combo of the big tubes and the big-bearing housing use a larger bolt, and you can NOT put a nut on the back-side of the housing flange for easier access. There is not enough room between the stud and the axle tube for anything other than a t-bolt.
      Just another delay, no big deal. lol
      NO ACCESS WINDOW >>>>>>>>
      This is what it should look like >>>>>>
      I have my work cut out for me this weekend!
      Old rear is out, taking a break to eat and then back at it!
      Nov 2012
      ...CONT'D
      Rear lines are plumbed, rear brakes are bled and work great. The gears are perfect, awesome difference in all gears under acceleration. Now I need to raise my rev limiter from 6000-6500 RPM.
      The lines came out really clean. Note the relocation of the line going from the body to the axle housing. Why Ford couldn't do this to begin with perplexes me.
      N. Carolina
      Loving it! What rear suspension is this? Is it possible to run the exhaust all the way out the back? Curious because I am building a 69 Fastback.
      Houston, TX
      Nice project. I'm working on a 68 Mustang, and will start a project thread soon. Will be following this.
      Tu Ho
      Firebird V2-LS swap
      N. Carolina
      My bad! Just read where it is a Maier rear suspension.
      Quote Originally Posted by 69SSLS1 View Post
      McKinney, TX
      I think the car looks better over on this site, welcome!
      89 Mustang "Box Wine"
      Sep 2008
      Sacramento, CA
      Great car! Looking forward to seeing you install all the front suspension.
      Carl Ogren - Sales and Tech
      Email us to get your Chassisworks/TCP Equipped vehicle featured on Facebook!
      Chris Alston's Chassisworks - Phone: 888.388.0297 ext 247
      Chassisworks - TCP - Varishock - Component Drive Systems - KP Components
      Nov 2012
      Thanks for kicking me in the butt to become a member instead of lurking in the shadows...lol
      McKinney, TX
      Hell ya, this site is a bit more welcome to custom stuff, nothing against the other one but still. Looks killer, makes me want to stripe mine.
      Nov 2012
      <<Thanks!, so far this place is more my pace. Talk about a lot of cool builds!
      ...Here's the engine upper-end build. (lower end had less than 1k on it but needed a little "spring in its step" ...no pun intended)
      Oct 2012
      British Columbia
      That is a really dramatic before and after. Great job on the overhaul and I have to admit I'm not a fan of the Mustang notch back but you may have converted me with this one. Very nice car
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
      Nov 2012
      Thanks Todd. Don't get mad but I sold my '67 Shelby fastback and bought this car (various reasons and long story) LOL.
      ...Cars are my drug and I don't need intervention
      Therapy provided by: https://www.pro-touring.com/showthre...ang&highlight=
      BK
      Nov 2012
      Quote Originally Posted by kmdracer View Post
      Looks nice!
      Thanks!
      Really nice work!
      I try and most of all I enjoy the time spent, Thanks!
      Quote Originally Posted by rickpaw View Post
      Please do!
      Quote Originally Posted by Carl @ Chassisworks View Post
      Thanks for the post Carl. I plan on taking this out to the Goodguys Autocross next season in Pleasanton to show it off with the crew and see how she does. I will be picking the parts up from you guys here in Sacramento AS SOON as they are ready. ...We are a dealer for your products and appreciate doing business with you on a regular basis. You guys are great to work with! ...if you will, please note in my EDITED first post just how I came to my decision on the front suspension. I've always wanted to try your front suspension on my own ride and I'm happy to say I finally have the opportunity.
      Quote Originally Posted by Todd in Vancouver View Post
      Thank you!
      Thanks for enjoying this with me everyone, I can't stress enough that this car is in the "mock-up and test phase" and will be a lot nicer to look at once all the major mechanical parts are installed and tested. I've learned my lesson in the past with "test mules" and nothing sucks worse than trying to strip off undercoating and re-weld parts! I promise to give the undercarriage and the engine bay a once-over detail soon! ;) lol.
      BK
      Jan 2011
      What are the wheel and tire sizes. Looks like they fit well
      Nov 2012
      Quote Originally Posted by nastyn8 View Post
      ...jogging my memory here since I got them already mounted and balanced from the 68 Mustang I parted out. The wheels are 17's and I believe the rears are 10 or 10.5 and the fronts are 9 or 9.5. Rear tires are 275 wide and the front are 245 or 255 wide. Series is 40 I believe. ...I can take a look and give you a better answer if you'd like...lol
      BK
      Oct 2012
      British Columbia
      Quote Originally Posted by bwkelley76 View Post
      Not sure if it's just age catching up with me and don't get me wrong I still love the classic hot rods, but, there is just something really cool about taking something that not many other guys have and building something cool. You are absolutely right that a fastback would be my first option but I just like the fact that you are not doing the everyday thing. Having said all that I went and got myself a first gen Camaro cause there are hardly any of those being built here on this site.
      Todd
      Project Obsession
      If I could weld like you, I might be able to score a seventh job!
