Results 1 to 20 of 61
05-23-2009 #1Registered User
- Sep 2007
- 424
does the fully-framed chassis get a bad rap?
This whole post is just a big theoretical B.S. session.
Of course, in practice, most of the car unibodies that we deal with in this hobby are much better platforms for PT cars. And even in theory it's MUCH better to build a frame in the third dimension that just length and width. Advantage: unibody again.
But once in a while I look at fully-framed cars and trucks and think the performance car hobby totally writes this setup off a bit too quickly.
It's just that the VAST majority of the perimeter/ladder frames I have ever seen under anything, they aren't even starting to try to be stiff. It's like the designers just crossed off that whole category when they were evaluating their priorities.
I see tons of open C-channel rails and crossmembers in places that obviously call out for boxed materials. Not to mention open-sided stamped-steel crossmembers that are only welded (or even just bolted) to only one plane of those side channels.
I mean, if they had been building most of their unibodies like this for the last 40 years then we'd probably be calling that design a piece of sh*t too. Some of the same "difficult compromises" needed to stiffen up the body-on-frame setups look like stuff that would be treated as foregone conclusions on a unibody chassis.
I don't see a ton of 3rd-dimension structure in most unibodies either. At least not on anything older than the mid-1980s. They've got some roof pillars and doorjambs and stuff to help a little, but I see very little additional structure over and above what a BOF car from the same era would have had in its separate body.
And yet we consider these older unibody shells pretty stiff compared to a body-on-framed setup. It makes me think our overall perceptions about the stiffness of a BOF setup must be pretty damned bad.
The weight issue fails to impress me too. Just eyeballing things, I see maybe 100 pounds of extra weight on a fully framed car in relation to a unibody car from the same era & type.
And then let's compare that unibody chassis again AFTER we're done adding our beefy subframe connectors and rocker box plating over the underside. (This is stuff that we need to do in order to "stiffen up the floppy factory chassis" on these old unibodies, remember?) Now the difference is even smaller still.
Bushings? Tightness of the chassis versus isolation? "Road feel?"
I've heard truck designers saying that they've had to soften up the control arm bushings on truck platforms as they switch them over to unibodies. Not only that, but how many modern unibodies (and not just the luxury-floppy ones) are using rubber-isolated subframes at one or both ends? The unibody's supposedly huge-foregone-conclusion advantage slides again.
The whole picture I see is a small advantage to the unibody setup but not the radical difference that we think of them having. It just doesn't look to me like we've ever seen many apples-to-apples comparisons of these two setups. Maybe in the truck world now and then but not much in sporty cars.
05-23-2009 #2
