Thread: LS3/TR6060 swap into a 68 Camaro
04-15-2021 #1
- Apr 2021
- 2
Hi Guys,
New poster here. I'm building a pro tour Camaro with an LS3/TR6060 swap going in. I picked up the whole setup with pedals and everything off a donor 2015 Camaro, whats the best way to setup the clutch for this type of swap. The donor clutch pedal doesn't seem like it would fit. Should be able to make the gas pedal work. Anyone make a conversion kit that makes this simple?
Thanks!
04-15-2021 #2Registered User
- Oct 2011
- 697
You need this kit from McLeod, come with everything including a new clutch pedal. You will use the slave cylinder that comes with the trans.
https://www.summitracing.com/parts/mcl-1434002
You will also need this fitting to connect the an line that comes in the kit to the clutch line at the trans.
https://www.summitracing.com/parts/ear-652504erl
You might as well pick up this bleeder as well. It will make bleeding the clutch much easier.
https://www.summitracing.com/parts/hmi-tpsbl5gMy Very Ambitious 69 Build
https://www.pro-touring.com/threads/...lls?highlight=
04-15-2021 #3Registered User
- Apr 2021
- 2
04-16-2021 #4Registered User
- Aug 2004
- 149
