    Results 1 to 20 of 32
    Thread: Cooled Seats
      Feb 2018
      London, Ontario Canada
      Cooled Seats
      More manufacturers are making vehicles with a/c in the seats. Has anyone here successfully installed them in a first gen? It does seem like it would be very complicated and not worth the bother as I'm not living in Texas, but if it's somewhat feasible it would be nice to have.
      Chuck
      Jacksonville, FL
      I just bought a used set of Recaro Specialists I would love to do this to!
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Feb 2021
      Florida
      Does such thing exist? I am honestly not aware but I think that's cool.
      Jul 2019
      Ohio
      My 2015 Silverado has AC seats, the 2016 model year switched to ventilated seats, no cooling. The AC seats use a peltier cooler that vents out the back of the seat towards the rear seats. The seat surface has some tiny pinholes in it to let air through. Not sure if they made the change to save money or due to complaints / failures, but they work very well.
      Red Deer, Alberta, Canada
      Quote Originally Posted by srode View Post
      They changed it because of rear passenger complaints. I have a 16 and with the ac seats on, the rear passenger gets pounded with hot air out the vents.
      Matt
      Instagram: Cst_koon
      Jul 2011
      Nashville/ Tampa
      Actively cooling the seats would end up producing heat somewhere. Tapping into the AC ducting could potentially be an option, but likely more trouble than it's worth. My ventilated recaros might do something to help dry the seats on a sweaty-back day but of course they provide no legit cooling.
      Feb 2018
      What I'm getting at is if you hop in a Merc or Porsche the seats are cooled, not ventilated. Very noticeably cool. Has anyone taken seats from one of these vehicles and used them in a first gen? There are some very smart people on this site, wondering about how to hook up to the seat to get them to function. Likely a tall order but if doable would be nice for summer.
      Dec 2018
      Quote Originally Posted by Canadianwraith View Post
      Where there's a wallet, there's a way lol
      Jul 2017
      Island Lake, IL
      This guy I used to be good friends with was working on water cooling his Kirkey seats years ago in a '95 Mustang. I stopped talking to him about 5 years ago so I'm not sure if he ever finished the project.
      This would be a cool project to see complete. Always nice to see people pushing the edge on pro-touring. If done on a budget....even better
      Sep 2007
      IMO the most trouble-effective way is probably to swipe some cool air from the rest of the AC system.
      Run some hose/ducting from the HVAC system, maybe contained in the center console, and then out under the front seats. The last step of the process (where the air hits the seat vinyl/leather) would be one of the most important parts of it. The air does need to flow so it's going to need an outlet point too.
      Done right, this setup might use a noticeable amount of AC air. But that's the point. That is cool air well-spent. Just insulate & seal up the system on the way to the seat vinyl so it's not wasting any of it. And give each bucket a manual shutoff method of some kind.
      Feb 2018
      I think I may pick up a set of cooled seats to see if there are a/c tubes running into them. My other concern is how to hook up the electrical to make the seats fully functional
      May 2010
      kitchener,Ontario,Canada
      Alot of modern seat do tie into the BCM , something to do with the air bags, weight sensors etc
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Feb 2018
      Ya I don't think this will be easy Ryan, I'm going to touch base with an electrical engineer to see what I need to do just on that side of the seat.
      I do have a set of seats that are heated but I'd like a cold butt too
      May 2010
      Its a super cool ( insert dad joke ?horrible pun ) idea but I don't think it is worth the effort ???? i want to think you could by pass some of the AC thru some custom ducting thru the seat foam and out some perforated leather would be the easiest , again not sure it would be worth it but , don't let me stop you as I'm interested to see how or what you figure out.
      Ryan Austin
      Feb 2018
      Gotta look into it more but I know Merc S550 have great cooled seats. There has to be a/c lines already running thru to the back and seat area. Should be a feed at the bottom to tap into.
      Apr 2010
      Jersey Shore
      I believe the merc seats have heat exchangers in them, the vents on the rear are the exhaust. You’d be better off plumbing your AC into the ductwork that is build into the seat and ditching the heat exchanger. The other issue with the merc seats is that the position controls are on the door, meaning that the motors and heating elements in the seat are controlled by the canbus. If you’re electrically handy, you could wire in your own switches directly to the motors and heating elements. Plenty of cars from the mid 2000’s that have nice looking high current seat position switches that you could use.
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Sep 2007
      Are there complications from putting both electric heaters and cooling lines in the seat at once? They have to occupy the same space.
      Feb 2018
      Chris, thanks for the info. I'm thinking now that it is going to be more work than it's worth
      May 2010
      check out first gen CTSV seats ,they do come heated and cooled , not sure thou about the wiring . I do know same era GTO seats aren't on CAN-BUS
      Ryan Austin
      Feb 2018
      Thanks Ryan, I'll check it out
