    Results 21 to 40 of 48
    1. #21
      Wisconsin
      Quote Originally Posted by Smooth67 View Post
      Nice work, parts are stupid nice, car will be awesome!
      I see the foil tape you used, but what is the actual sound deadening material?
      The foil is from the hardware store (heating and cooling), I found the sound deadening sheets at an audio supply store on-line. It's dense, and once it's down, it's down. Does a real nice job!
      Used to be known as classiccamaro
    2. #22
      Wisconsin
      A little more progress on 69 updates. Getting the rear brake lines bent up for the DSE / GearFX 9 inch housing and Making some room on the firewall for the LT4. Name:  IMG_0449.jpg
Size:  72.2 KBName:  IMG_0435.jpg
Size:  43.3 KBName:  IMG_0437.jpg
Size:  46.9 KBName:  IMG_0439.jpg
Size:  45.4 KBName:  IMG_0450.jpg
Size:  76.3 KBName:  IMG_0451.jpg
    3. #23
      Wow it all looks great!
    4. #24
      Wisconsin
      Thanks, Getting more "garage time" these days!
    5. #25
      Wisconsin
      More updates on the 69 "re-do". With the installation of the DSE sub, LT4 and Holley mounts...I had to make a bit more room in the trans tunnel for the T-56 and shifter. Fabbed up a new "pocket" for the shifter to live in.....almost time to repaint the underside and start some assembly....
    6. #26
      Wisconsin
      Getting the underside painted and some Raptor Liner applied...All the fab work for the DSE suspension complete. getting close to reassembly!
    7. #27
      Wisconsin
      Assembly time! Sub frame sanded, painted, and assembled. Bolted on some BIG brakes courtesy of Bear Brakes.
    8. #28
      NJ
      Looking real good! You're moving at a pretty quick pace!
    9. #29
      Wisconsin
      Thanks John...... How is the 69 coming along??
    10. #30
      NJ
      Good just gathering some more parts and will hopefully be at the fabricator by the end of the week! Can't wait to start making progress!
    11. #31
      Wisconsin
      Setting up the air gap on my throw out bearing, I needed to move the bearing out. The solution was a machined spacer from Mantic Clutch USA. MUCH better than the stacked spacers...... the machined spacer, properly locates the bearing over the input shaft. Getting closer to getting the DSE sub / engine back in the car.
      https://manticclutchusa.com/
      https://www.youtube.com/watch?v=8_R52-3uDXA
    12. #32
      NJ
      Looking good! What are you doing for brake lines up front? Just making your own?
    13. #33
      Wisconsin
      Thanks John, I'm bending all new brake lines myself, 3/16" front and rear. Do you have a build thread on your car?
    14. #34
      NJ
      Quote Originally Posted by DKz Garage View Post
      I think I'll be doing the same.
      Build thread link is my signature.
    15. #35
      Wisconsin
      The reassembly begins on the 69 updates... Received my Speartech wiring harness........ the workmanship is awesome. The rear end and DSE Quadralink gets installed. Name:  <span style='whitespace: nowrap'><a href='https://www.optimabatteries.com/en-us/redtop-starting-battery?utm_source=ProTouring&utm_medium=Display&utm_campaign=FY%2719_Brand_Media&utm_content=RedTop' onclick=battery.jpg Views: 558 Size: 129.4 KB" style="float: CONFIG" />Name:  rear 1.jpg
Size:  161.9 KBName:  rear 2.jpg
Size:  139.6 KBName:  rear 3.jpg
Size:  173.4 KBName:  wire 1.jpg
Size:  225.2 KBName:  wire 2.jpg
    16. #36
      Wisconsin
      Turned the corner today....installed the DSE subframe, Speartech harness, Drive Junky Front drive, and the LT4. Also fabbed up a bracket for the inter-cooler pump.
    17. #37
      Jul 2018
      beautiful
    18. #38
      Germany
      Country Flag: Germany
      Wow, very nice brakes, color combination, parts and work !!
    19. #39
      NJ
      Damn! Someone's been busy! Looking good!
    20. #40
      Wisconsin
      Quote Originally Posted by Autobahn-Outlaw View Post
      Quote Originally Posted by Just 1 More View Post
      beautiful
      Thank you for the feedback...... Trying hard to get it back on the road this summer, the whole Covid thing is slowing the process :( (parts).
