    Page 16 of 19 FirstFirst ... 6 11 12 13 14 15 16 17 18 19 LastLast
    Results 301 to 320 of 363
    1. #301
      Jan 2021
      Alabama
      looks awesome. Amazing work all the way through!
    2. #302
      Sep 2017
      Quote Originally Posted by wareaglescott View Post
      Thanks man yours as well. I've had my eye on your build all the way through and it's been impressive and you've made great time on it as well.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    3. #303
      Oct 2016
      congrats Jason you made an awesome work, she is the sexiest one
    4. #304
      Sep 2019
      Country Flag: New Zealand
      Well done, looks awesome.
      When I die don't let Nina sell my car for what I told her it cost to build.
    5. #305
      Sep 2017
      Quote Originally Posted by berdunord View Post
      Thanks Bernardo!
      - - - Updated - - -
      Quote Originally Posted by mistral View Post
      Thanks it's appreciated
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    6. #306
      Dec 2015
      Arkansas
      Congrats Jason!! Looks amazing sitting out there
      '67 Camaro SS - Currently in build stage but making progress!
      **Brett**
    7. #307
      Sep 2017
      Quote Originally Posted by Smooth67 View Post
      Thanks Brett how's yours coming along?
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    8. #308
      May 2012
      Kansas City, Missouri
      Cars looking awesome. Love the grille and the white really pops
    9. #309
      Sep 2017
      Quote Originally Posted by thumper877 View Post
      Thanks , I was concerned about enough pop with no black up front. I'm thinking about making another grille of the same mesh and painting it black so I can compare, or maybe even paint the fiberglass surround black andeave the grille aluminum.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    10. #310
      Sep 2017
      Alignment
      Working on the alignment now. I got the toe set a 3/32 toe in and the Camber at 1/2 degree negative. Now I just got to line up the Caster to 4-4.5 positive. Using Speedtech subframe recommended settingsName:  IMG_20220920_195537.jpg
Size:  268.0 KBName:  IMG_20220920_195543.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    11. #311
      Västerås, Sweden
      Country Flag: Sweden
      The car looks super nice, Jason!
      Do you know what scrub radius you have? From the look of the wheels, it looks like you wanted to keep it low.
      Henrik
      "Mechanix Menace": An LS7-motivated, chopped, tube framed, and heavily modified 1973 Datsun 240Z
      https://www.pro-touring.com/threads/...73-Datsun-240Z
    12. #312
      Jun 2017
      Utah
      Wow, what a great build and a huge inspiration. Congratulations.
    13. #313
      Sep 2017
      Quote Originally Posted by Threepointtwo View Post
      Thanks for the kind words. It's closer but seems never done lol.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    14. #314
      Sep 2017
      9" leaks
      So my Speedtech torque arm rear end 9" leaked at both ends. Mine had the roller outer sealed bearings. So I decided to re engineer a little. So I installed the winters performance #2842 gold billet aluminum axle tube seals to keep the oil in the center section. I then drilled and tapped 1/8"-27 holes in the ends of the tubes between where the original inner axle seals went and the sealed roller bearing. I installed a 90 grease fitting here right on top. So I then installed the original national axle tube seal, and then removed the inner plastic seal on the roller bearing so it will receive the grease. So my grease fitting puts grease in between the original style tube seal and the now open side of the roller bearing.
      It's .625 cavity there.
      I'm now keeping oil in the center and greasable outers separate by the two styles axle tube seals.
      What do you guys think?Name:  IMG_20221127_203923.jpg
Size:  191.9 KBName:  IMG_20221126_165550.jpg
Size:  209.0 KBName:  IMG_20221126_165556.jpg
Size:  250.1 KBName:  IMG_20221126_165607.jpg
Size:  148.6 KBName:  image000000.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    15. #315
      Sep 2013
      sw Kansas
      I'm sure you know this but if you over lube a bearing, it will overheat and fail. I fought a leaky bearing as you did. I replaced the oring numerous times. Only by accident did I pull on the axle flange and find out there was slack in the bearing. It was starting to fail. After replacing the bearing, the leak went away. In my purchases of new bearings in the last 15 years, I'm right at a 20% failure rate. New parts make me nervous anymore. Some brands are worse than others but none are like it was when I was young.
    16. #316
      Sep 2017
      Yes
      Lip seals can fail typically around 500psi. Trick is don't over lubricate. Good thing in my design if I pump just a little bit much it will pass the lip seals and merely get on the dry zone of my axle. Once a year a few pumps will be sufficient but I do have a pressure gauge setup on my battery powered grease guns for certain applications.
      To prove just how strong grease under pressure is with a cup seal we tighten tracks on dozers and all track machine we own with grease. But the cup is pointing towards the grease fitting. In this car application the cup points the other way towards the oil end or center section to keep oil out of the grease. Thus even lowering the pressure it would take to bypass the seal.
      Case in point your correct.
      But I have considered this and engineered my design around your line of thought along with several others.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    17. #317
      Sep 2017
      Nuke performance catch cans
      Well I started with one nuke performance catch can, and excellent excellent quality. But I had valve covers and valley cover both plumbed into it. Then I separated the valley cover and just looped it back like factory. Then I decided to add a second so the valve covers and the valley cover pcv had its own.
      Again if anyone wants some very nice billet catch cans, nuke performance has race cans, performance cans, and even carbon fiber cans.Name:  IMG_20221128_185142.jpg
Size:  194.9 KBName:  IMG_20221128_185126.jpg
Size:  227.9 KBName:  IMG_20221128_185059.jpg
Size:  208.4 KBName:  IMG_20221128_185047.jpg
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    18. #318
      Newbury Park, CA
      Having spent a 28 year career in bearings.....
      Your relubrication feature should work fine. One challenge with the design is the cavity space on the lubrication entry side is quite large vs. the void space in the bearing. There are a ton of variables here, but.....
      1) Due to the design of the inboard seal vs. the outboard seal of the bearing, grease is going to tend to work outboard. Most of the axle seal designs are a double opposing lip design, whereas the seal on the bearing will easily deflect outboard and allow grease to purge. This is normal and often expected on sealed type bearings. It's going to purge what it does not want.
      2) Though over-lubrication is often a serious problem, it typically occurs when the dN (rolling element pitch diameter * RPM) is high. A drive axle is a relatively slow application, and likely excessive grease will purge before an overheat condition occurs.
      What can be done that is quite effective is to fill the bearing full of grease, and then fill the cavity space about 50% full/about to the axle bottom of grease. Excess from the bearings will purge inboard. There will be 50X+ more grease in the cavity than what the bearing comes with from the manufacturer. As speed and heat dictate, fresh grease will flow into the bearing. In a bearing that size there's likely 3-4cc's as the standard fill volume. In other words, no need to ever re-lubricate unless the axle is removed. Then everything should be cleaned and re-lubricated. The same basics can be applied to a stock front hub with double tapered roller bearings (fill the hub 1/2 full).
    19. #319
      Sep 2017
      That's awesome insight to a seemingly simple setup. I appreciate the explanation and I love to learn. I definitely have with your reply.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    20. #320
      Nov 2022
      La Center, WA
      Super nice work! Love the progress. Great motivation for me!
      Martin
