    Results 1 to 11 of 11
      Aug 2011
      Sevierville, TN
      Your thoughts on wheel spacers/adapters
      If I want to buy some wheels with a different lug pattern, would I be ok to run some spacers/adapters while autocrossing? Would the stress be too much? for the spacers to handle?
      Matt Kenner
      68 C10 stepside
      If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
      Aug 2010
      Seattle area
      Thats an awful strain in you lug nuts,Plus the offset maybe wrong with the adapters.
      I"ve been running the same adapters (not spacers!) since 1998 when I put on my C4 Vette wheels. Haven't raced with them, but I haven't been gentle either. Never had one iota of trouble with them.
      Again, these are not spacers. They bolt to the wheel hub like a wheel. They then present a separate set of lugs to the wheel itself. 6061-T6 aluminum... they're very strong and I seriously doubt you'd be able to break them.
      1971 Camaro
      Oct 2012
      I heard an interesting concept once.... a brake rotor is basically a small wheel spacer!
      Feb 2007
      Tinley Park, IL
      A high quality bolt on spacer/adapter is nothing to worry about.
      It's the excessively thick slip on spacers that cause problems. I have no testing data to back this up, but I personally would not feel comfortable with a slip on spacer more than 3/8" thick.
      Nick ~
      1969 Cutlass
      Dec 2008
      Detroit
      Look at motorsport-tech.com. They make hubcentric wheel adapters.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Aug 2011
      Sevierville, TN
      I should've included a bit more info. I would need a 1.25" spacer and adapting to a different lug pattern, so the bolt on style is the only option. That being said, you guys answered my question about them being ok as long as I buy quality adapters(which I would have anyway.)
      I have ran 7/16" slide on spacers before with the extended shank lug nuts. They never gave me issues, but I checked torque on them every time I drove it just for added peace of mind.
      Matt Kenner
      68 C10 stepside
      Dec 2008
      Detroit
      Quote Originally Posted by Slick68 View Post
      I should've included a bit more info. I would need a 1.25" spacer and adapting to a different lug pattern, so the bolt on style is the only option. That being said, you guys answered my question about them being ok as long as I buy quality adapters(which I would have anyway.) I have ran 7/16" slide on spacers before with the extended shank lug nuts. They never gave me issues, but I checked torque on them every time I drove it just for added peace of mind.
      I think we understood. The address to provided is a company the makes hub centric wheel adapter spacers. They will convert the lug pattern and they are a tight fit to your center hub on the axle or front wheel hub... Only company i would use.
      Chris--
      Nov 2016
      Sulphur, La
      I run a 1.5" adapter on my jeep and have for over 6 years. 40" tires and nitrous in a rock rig. Have not had any issues with these.
      Jul 2011
      Nashville/ Tampa
      Just checked their site out and went through a mock purchase; very nice interface and definitely who I'll use when I order my adapters
      Oct 2014
      DFW, Texas
      I ran 1.5" lug centric spacers with 140lb wheel assemblies [yes, 140lbs per wheel] on very demanding rock crawling situations for 75k miles. I have no worries running spacers..
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
