    Results 1 to 15 of 15
      Aug 2018
      68 Camaro RideTech 4 link tire size
      This is my first post so bear with me.. Maybe I am posting this in the wrong place.
      I'm building a 68 Camaro protour/autocross car. I just finished DSE minitub and have plenty of inner fender clearance. Question is anyone running the factory 12bolt and ridetech 4link with 335's? Looks like I can clear a 18x12 wheel with about 7" backspace and probably roll the outer finder lip or 7 1/4" would completely tuck the tire in the fender but looks like the side wall of the 335 at that point (estimating 4"profile with 13.5" section width) would be very close to the lower ridetech coil-over mount. Budget will not allow a custom rear-end and I would rather not narrow the factory 12bolt. I know cars this old are all going to be a little different but if anyone already has experience here it would be appreciated. Looks like most everyone is running a 9" or complete aftermarket rear end. Wish i had the budget for that but its already spent and then some... I know 315 would be a easier fit but looks like most of everyone is running the 335 BFG Rival at all the events.
      I know there is no exact yes or no answer here, just looking for any similar experience/insight.
      Thanks!
      Pensacola, FL
      I had to use the weld on ridetech shock mounts, as the wheel/tire contacted the bolt on mount that attaches to the factory spring perch. This was on a 12" wheel w 315 tire, with a narrowed rear housing. Backspace was 6". On a stock width rear, 7" or 7.25" BS sounds right. A 315 is a pretty easy fit on an 11" wheel. That may also allow you to use the bolt on shock mounts. I have seen 335s on several 67/68s, but I have found each car is a bit different as far as fit. I dont think you'd give up much/anything at all with a 315 rival, especially if you are running a 255 or smaller up front. I'd still roll the fender lip for piece of mind. With some careful measuring you should be able to determine what will fit with your setup.
      Aug 2018
      Thanks for the suggestion about the shock mount. So with the weld on I could move the mount inboard but then I would need to shorten the axle and the geometry ridetech has done all the design work on would change. Or am in miss understanding and the weld on mounts provide more clearance in the same location somehow? I only see 3 sizes available in 18" Rivals. I was planning to run the 275/35 up front on a 18x10 with the ride tech tru-turn etc.
      Apr 2004
      OKC, OK
      335 rival will be a very tight fit and will probably have some rubbing issues without extra work to make clearance for them. 69 has wider quarter so it is easier to run a 335.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Don’t want to burst your bubble but 275 up front with tru-turn might be tough. You will have to nail the backspacing and run a lot of negative camber. Even then rubbing is possible. No need for a 10 inch wheel for a 275 tire.
      Jonesboro, Arkansas
      I'm not trying to steal your thread, but I have a question. Can you roll a rear fender after the car has been painted? If so, how is it done?
      Carl Wilson
      Jacksonville, FL
      I am running the full ridetech 2 level package in my 68. I am running Kore3 C5 brakes front and back. I used a stock width bolt in 9 inch rear (exactly like your factory 12 bolt) with the factory style leaf perches welded on. I autoX my car and run these sizes-
      Front 18x9 with 5.625" BS with 265/35-18
      Rear 18x11.5 with 7.625" BS with 315/30-18
      I use Falken RT-615K+ tires and the only rubbing I have is from the inner tire on the subframe while trying to park. No other rubbing or issues. This combo does really well. I guess it would be possible to run a 275 up front, might try it on my next set of tires. You can run a 335 on a 67/8 but like it was said earlier, the BS has to be exact. I have plenty of clearance (other than the subframe rub) front and back. I drive the car all over on the street and autoX tracks and have no problems.
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Aug 2018
      Thanks for the good info all!
      My car is not painted yet and I have no problem with the sheet-metal/fab work for rolling fender lips out back or modifying the inner fenders in the front. That will cost me nothing but time and sweat. My issue is tight budget at this point. I wish i could afford a set of Forgelines along with their tech support to get the fit just right.... But I cant drop 6K on wheels. The wheels with the look Im after and at my price range in 18" they do not come in 1/2 sizes. So 18x12 or 18x11 but with lots of offset/backspace options so im pretty sure I can get the backspacing right. I made a kind of home brew wheel fit tool. Unknown is the way the sidewall will profile out back on different wheel tire sizes/combos.Name:  wheel snip.jpg
Size:  15.0 KBPics of the wheel tool are representing a 335 on a 12" wide wheel with 7.25 backspacing. Too close? what do you think? I will need to remeasure when i receive my rear rotors but just trying to get a feeling of whats possible. Thanks again for all the help. There is a amazing knowledge base here. This is a big decision for me and need to get it right.
      Anybody have any sidewall pics of a 315 on a 11" wide wheel? 18" BFG Rival or Falken RT? Or is there negative performance attributes to putting a 315 on a 11 vs 11.5?Name:  IMG_0541.jpg
Size:  172.5 KBName:  IMG_0542.jpg
Size:  171.5 KBName:  IMG_0544.jpg
      Bump for more... hoping to run 335s on the rear myself.
      http://i133.photobucket.com/albums/q47/tim_bo16/004-24-1.jpg
      Jul 2018
      325-30-19's on 19 x12's 5.75 backspace 54.75" rear axle to axle rolled lips. I think I could have done 345's
      255 -40-18's front
      20210514_173950 by F G, on Flickr
      20210514_174912 by F G, on Flickr
      Apr 2007
      New Jersey
      This is a 325/19 which is tight. Z06vet (Scott) might recognize the car...
      Rolled fender lips tire tight to lip and about 3/4 away from the ridetech shock mount. No rub, no issue when back seat has passengers.
      Doug L.
      68 RS/SS Conv. LSA/T56.
      67 RS Coupe LS2/T56 named "NutKse"
      Nov 2010
      So what did you end up going with? Having same issues trying to find wheels and tire combo
      - - - Updated - - -
      Quote Originally Posted by thedugan View Post
      what is your wheel tire combo? Stock width rear?
      having hard time finding right combo
      Apr 2007
      New Jersey
      In my case it's a narrowed rear. I have a deep dish. In your case you wouldn't
      Wheels are Rushforth 19x11 .
      Tires are 325/30/19
      Let me know if you need anything else
      Doug L.
      Nov 2000
      O-town
      67/68, depending on the replacement or factory quarters, I actually have GM quarters on my car, and the lip is very big on both, to run a 335 which I have, trimming is greatly required!
      But like discussed ever since I have been on this board, the difference in how each car is made at the factory, between the 2 years and even the same year cars,
      as they say, measure twice cut once!
      Jul 2019
      Ohio
      Quote Originally Posted by 68LSAutoCross View Post
      The place to check for clearance is fully compressed shock length on the inner wheel well and outer wheel well in the top
      1/3 of the tire rotation. I took the shocks off to make the measurement on my 69 and measured with the car supported on the rear rockers and moved the rear end up to where it would be fully compressed on one side, level and then with the other side lowered a bit to simulate a hard turn. You want about 1/2 inch clearance all the way around to have a safe margin. 1/2 inch at your shock too would be recommended. Remember your wheel comes up from that inner tire bead too so just because your tire clears the shocks doesn't mean the wheel will necessarily. On the front of my speedtech frame the tie rod to wheel spacing is the restriction for turning radius, not the tire or frame.
      A narrower rim will pull the bead in but gives a little more sidewall movement so folks running on a track may prefer rims on the wide side of the recommended range vs middle. The narrower rim probably gives a bit more cushion in the ride though due to sidewall flex going over bumps.
