    Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
    Results 41 to 60 of 179
    1. #41
      Jul 2015
      Winfield MO
      duvall408w
      It does have a front and mid plate, I wanted to build our own headers and I can't see how they can sell a set of 304 ss headers $200 and stay in business very long. I got more than that in the flanges. Haven't decide on rear gears yet. Probably end up with 2 third members to reach both goals. I guess it depends on who you talk to on the 4l80e trans but I was told due to the small dia gears they wouldn't hold to the load (not talking about shifting) with high HP and 230/240 speeds. Some guys are spraying oil directly on the OD gears to make them live. Engine builder at Venom Racing Engines tells me we should have around 1400 HP for the street and around 2400 HP and be safe on the tune. He builds a lot of turbo ls stuff and the head guy familiar with the mile run stuff.
    2. #42
      Jul 2015
      Winfield MO
Size:  98.0 KBName:  IMG_0387.JPG
Size:  115.2 KB Mocked up the rearend and watts linkage
    3. #43
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Very nice indeed!
      1966 Plymouth Fury III
    4. #44
      Jul 2011
      Prescott, AZ
      Quote Originally Posted by UDOIT View Post
      duvall408w
      That is some SERIOUS power! We guess that probably isnt much compared to the nitro drag cars you've dealt with, but no doubt still scary in any street car!
    5. #45
      Jul 2015
      Winfield MO
Size:  95.3 KB[ATTACH=CONFIG]137865[/ATTACH Transmission with Gear Vendors overdrive attatched.
    6. #46
      Oct 2016
      impressive ! really nice build
    7. #47
      Jul 2015
      Winfield MO
      Off the Jig. Transmission and torque arm installed
    8. #48
      Jul 2015
      Winfield MO
Size:  110.4 KBName:  IMG_0449.JPG
Size:  104.5 KB mocked up the radiator and steering
    9. #49
      Jul 2015
      Winfield MO
Size:  112.4 KBName:  IMG_0482.JPG
Size:  113.6 KB[attach=config]139691[/attach Installed exhaust side tubing, some sheetmetal, and steering wheel. Hope to intsall the intercoolers and intake side tubing and pedals next weekend
    10. #50
      Dec 2010
      Apex, NC
      Beautiful work!
    11. #51
      Jul 2015
      Winfield MO
Size:  77.3 KBName:  IMG_0500.JPG
Size:  108.8 KBName:  IMG_0501.JPG
Size:  105.2 KB Rough fit all the body panels Gaps ended up not being to bad. still need some work when we get it to the body shop Fit the brake pedal/master cylinders. Next up intercoolers and intake tubing
    12. #52
      Jul 2015
      Winfield MO
Size:  82.2 KBName:  IMG_0515.JPG
Size:  104.5 KBName:  IMG_0516.JPG
Size:  98.8 KB Fitting the intercoolers
    13. #53
      Jul 2015
      Winfield MO
Size:  92.4 KBName:  IMG_0526.jpg
Size:  79.2 KBName:  IMG_0519.jpg
Size:  82.7 KBName:  IMG_0520.jpg
Size:  104.1 KB Mounted the intercoolers and installed the intake tubes
    14. #54
      Jul 2015
      Winfield MO
Size:  108.1 KBLast of the turbo tubing fit and now to start welding. Next step is to build the dry sump tank and start routing lines
    15. #55
      Jul 2011
      Prescott, AZ
      That dual intercooler setup looks really aggressive and we would guess it probably has a little better response than using one large unit. Nice job!
    16. #56
      Nov 2002
      Georgetown,TX
      Does Gear Vendors offer an even heavier duty o/d unit? The ones I've considered purchasing were "limited" to 1,200hp.
    17. #57
      Jul 2015
      Winfield MO
Size:  90.6 KBName:  IMG_0573.JPG
Size:  72.4 KBName:  IMG_0568.JPG
Size:  102.5 KB Boxed in the frame where we had to run the intake tubing
      Centerforce;
      Don't really know what you mean by aggressive but after talking to Bell they thought this would be the best design. They are still not big enough when we crank up the boost but we tried to use the available space that we had and still keep the tubing as simple and efficient as possible.
      USAZR1
      You may want to check with gear vendors as they advertise on there home page over 2000hp. When we discussed our project with Hughes and Gear vendors they think it will handle the power just fine, Don't know if you follow drag week but Larson makes about 3000 HP and runs high 5,s Lutz does about the same. I was told by Steve at Hughes they only made a couple tweeks to the gear vendor stock unit. No so much with the trans
    18. #58
      Jun 2015
      San Diego
      awesome build!
    19. #59
      Jul 2015
      Winfield MO
      First rendering of track version. Still needs a few tweeks
    20. #60
      Jul 2015
      Winfield MO
Size:  123.8 KB Final Track rendering Street version shortly
