    Results 1 to 20 of 21
      Salinas, CA. 4.5 MI from the Corkscrew @ Laguna Seca
      68 Camaro RS LED headlights. What did you use?
      I'm looking to upgrade to LED headlights on my 1968 Camaro RS/SS. I understand they are a tight fit due to the headlight doors. I'm thinking of using United Pacific p/n 31391. Which LED lights did use and did you have to modify anything? Thanks in advance for your help.
      Dec 2020
      Don’t have depth issues but I went with Phillips H6024LED. Big name brand and solid price about $160 apiece.
      Was looking at Halley’s but yellow illegible WA and personally didn’t want a stock look.
      The don’t have the yellow in them in real life and just clear. Woulda loved something with clear lows and yellow highs.
      Rock Auto has them for $150 ea
      Nov 2014
      Byron, Ga
      Octane Lighting w/OE glass housing
      '66 Chevelle BBC/TKO600r, Holley Sniper EFI, Tanks Inc, RideTech Air Ride, Wilwood, Billet Specialties Toploaders 19"/20", Nitto NT555G2, Octane Lighting LED, DIGI-TAILS Front & Rear, Randy's Spoiler
      Jul 2018
      I'll second the Phillips H6024LED
      20210411_193104 by F G, on Flickr
      Nov 2014
      Lake Worth, FL
      octane lighting
      I have them on both my 69 & 68 RS
      not fitment problems at all, I didnt have to cut or trim anything and inexpensive
      Scott
      May 2009
      I went with JW Speaker 8700 Evo. Took a bit of trimming on the bucket but the lights are high quality and have great output.
Size:  395.2 KBName:  20211009_202859_resized.jpg
      Dec 2020
      Just got my Phillips in…. Nice light
      How did they fit on your RS? Any fitment issues with the back of the headlight bucket or closing of the headlight doors?
      Dec 2020
      Quote Originally Posted by TZmtrsprt View Post
      I should of noted I put mine on a 71 chevelle.
      Jul 2018
      I put them in a 68 Camaro RS with no bucket mods or any issues whatsoever
      Thank you! That is answer I was looking for. I'll be ordering a set. Thanks to all for your input.
      Jul 2008
      Napa carries the Phillips LED lights if you wanted a local option.
      *Jeff*
      Dec 2020
      I believe Napa stopped carrying the Phillips and picked up Truck Lite (Rigid I believe). Can’t find the Phillips on there site.
      Found cheapest on AutoBarn.
      Dec 2019
      Azle, TX
      The Holley Retrobright headlights will fit with no modifications, look totally stock and have much better visibility at night.
      https://screamingchicken.com/1967-69...ht-headlights/
      We also sell United Pacific headlights, their 31387 will fit if your using the Detroit Speed electric conversion or have stock vacuum operated lights. Some other kits locate the motor directly behind the headlights which can cause problems. We have some pics and more information on our website or your welcome to call me and I can let you know what to look for. Takes about 20-30 min to modify the metal behind the buckets. No issues clearing the RS doors and have a stock look.
      https://screamingchicken.com/1967-69...ight-kit-pair/
      We also have buckets, trim rings and hardware for the headlights at the link below:
      https://screamingchicken.com/camaro-headlights-1st/
      Holley Retrobrights
Size:  108.4 KBName:  1st-camaro-holley-retrobright-off.jpg
      United Pacific 3187
Size:  63.7 KBName:  1st-up31387-heise-headlights-installed-on-2.jpg
      Dec 2020
      Lights installed
      Apr 2007
      New Jersey
      I used VisionX lights from Headlight Revolution. Had to modify the bucket. Works and looks great. https://youtube.com/shorts/hIipyjaNRh4?feature=share
Size:  460.2 KBName:  IMG_0970.jpg
      Doug L.
      68 RS/SS Conv. LSA/T56.
      67 RS Coupe LS2/T56 named "NutKse"
      Dec 2019
      Azle, TX
      These headlights were out of stock most of 2022, but now have plenty in stock. These are an easy install on RS cars since the lights are not as deep as most LED headlights - no cutting or modifications of any type. They use 9007 bulbs so easy to swap bulbs years later. They have a built-in halo light also, the light can be used as a turn signal, running light or not used at all. Below is a picture of them on a RS Camaro from an install we did.
      Jonesboro, Arkansas
      Quote Originally Posted by Camaro68+69 View Post
      octane lighting
      Scott
      I'm with Scott. I've gad my Octane bulbs and glass housing for around 6 years and no problems yet. Bright and look good too!
      Carl Wilson
      Dec 2018
      Quote Originally Posted by slammed68 View Post
      Running the same headlights, like them a lot.
      - - - Updated - - -
      Jul 2019
      Holley retrobright on 68 w/o RS package. no modifications. Nice white lite with cut-offs.
