    Page 2 of 2 FirstFirst 1 2
    Results 21 to 33 of 33
    1. #21
      I really like the Fab work on your Rear Shocks!
      Why did you use a 944 Transaxle vs using a 901 or 915?
      If it were me, I would put a piece of 180 Degree bent piece of screen in front of your Front Oil Coller to keep Rocks from Punching through & Debris from Clogging it up.
      T.C.
    2. #22
      Jun 2013
      porsche powered mid-engine double cab
      Thanks for the kind remarks guys.
      T.C. It was my general design to run the pushrod shocks for space and travel reasons but my fabricator Seth Bomar made it all work.
      The reason for the 944 transaxle is that with a torque tube layout I could put the engine where I wanted it, in this case under the existing seat pedistal for access.
      I could also keep the torsion tube intact in my case I had Seth weld in the 944 torsion tube which locates and carries the rear suspension arms. It also helps that the 944 transaxle is cheap and in the case of the 944s2 version strong enough to handle the 3.2 Porsche engine (and hopefully the dual turbos I will add in the future!)
      I am still detailing the front bumper and actually made a screen frame some months ago but have since made the cooler opening smaller so need to re-size it, but your right, it is getting beat daily driving it on country back roads. I am also going to fair in the opening to smooth it out.
      here is a shot to show the drive-train layout. Lots more on my build thread.
    3. #23
      How are you getting Air to the motor?
    4. #24
      Jun 2013
      The air comes from the grills on the side of the truck, 66 and 67 model years had these instead of the grill on the rear sides, because the grill is so far forward v.w. had holes in the bulkhead leading forward and I took out the panels which seperated the rear of the truck to the cargo hold under the seat. The engine runs cool, rarely kicking in the secondary thermostat to the front bumper mounted cooler.
      My future plan is to hammer out some aluminum scoops to replace the stock louvers.
    5. #25
      Jun 2013
      I found some carbon fiber mirrors used off a race car from a shop at Sears Point Raceway.
      They weigh 5 ounces each and replace the stock bus mirrors which weighed in at 24 ounces!
      I went back to the same shop (Auto Spa) and put the d.c. on the corner scales, to get a rough tune , I will need to return after the front cage is fabbed and if I change my spring rates again to fine tune balance.
      The first #'s are without driver weight and no adjustments made.
      The cross weights were good and front to rear bias is about 50%, so far so good. Not happy about the overall weight at almost 3000#, this is with 3/4 tank fuel and 18 qt. oil in the dry sump.
      Things are about to get worse-driver weight added.
      note to self-refrain from cheese intake.
      This is what I ended at, decent cross weights and about a 54% front bias.
      We were also able to max out the front camber at -1.1 deg.
      This with changing the rear coil-overs from 400# to 550# springs should help the oversteer I had at my last autocross.I am looking to book a session soon to re-test.
      Note: those readouts are reversed.
    6. #26
      Feb 2013
      Yep
    7. #27
      Jul 2009
      Wartrace, Tn.
      Very cool build that ticks all the boxes for me - interesting, different, well executed, and being flogged in the real world. Thanks for doing this thread. It's definitely not the norm for this forum, and I hope it will encourage people to post the unusual without fear of being accepted.
      And where are the updates !!!!
    8. #28
      Jun 2013
      Thanks for the kind words Boatmark.
      No big updates to report, I did up my rear spring rates to 650# which pencils out to about 320# effective rate. Ran it at another autox event at Sonoma Raceway, the higher rate did help the double cab's propensity to understeer. Still need to get the front end to stick better, but I think I am running out of tuning options till I build a A-arm front suspension.
      Some fancy cars and a old bus/truck
      Some more work to the nose oil cooler
      Some detail on how the drivetrain connects
      Working for a living
    9. #29
      savannah,ga
      awesome build, love the whole thing.
    10. #30
      Jun 2013
      porsche powered mid engine double cab
      I am finally working on the front suspension swap, using the front off a Porsche 928s4.
      The front end is bolted up, next to do is steering rack and steering column.
Size:  159.4 KBName:  IMG_2997.jpg
Size:  210.3 KBName:  IMG_2995.jpg
    11. #31
      Jun 2013
      I have finished the final iteration of my suspension, mostly just tuning left.
      Front suspension specs: wheels O.Z Fittipaldi 8.5” x 17”,tires 235/40/17
      928S4 upper and lower arms, spindles, Brembo calipers, Rabbit rack&pinion
      Bilstein coil-overs 700# springs, 1.25” hollow splined sway bar .188” wall.
      Rear suspension specs: wheels O.Z. Fittipaldi 9”x17”, tires 255/40/17
      944S2 torsion housing, stock torsion springs, early offset 944 aluminum arms, S2 Brembo calipers. 1.5 ratio rocker arms connecting to Bilstein coil-overs 600# springs, 16mm 944S2 sway bar.
    12. #32
      Jan 2000
      Thousand Oaks California
      Very cool ride. I used to have a '65 van and I miss is so.
      Larry Callahan
    13. #33
      Sep 2011
      I can only imagine the feeling of fun sitting on top of the front axle. You have to optimize this thing. It could be the most fun autocrosser there is!
