Results 1 to 12 of 12
08-09-2005 #1
Which EFI system. TB , TPI . S ram, St ram
Ok I know Im not getting off cheap on EFI Ive tryed to find a Bulletproof way but no luck. I just dont want a pieced together system that may work one day and not the next.
So I have a few questions
Keep 380-390 HP Small block in mind
1) Is a system with a WideBand O2s worth the extra cash?
2) Is a throttle body set up worth looking into? Holley
3) What system type is the best for performance and economy
A) 4 BARREL tb WITH sfi on a single plane intake --Pro flo look
B) Ram type AKA Stealth Ram Super ram
4) What would be a good Upgradeable system
Thanks for your timeNothing says "I built this" better than tool marks and dykem blue..
08-10-2005 #2Registered User- Join Date
- Aug 2004
- 582
I think we should get a FAQ sticky going
THese types of questions have been asked many times, so i'd like to see a FAQ created. I have a word document going. It's already 4 pages long. Should I post it here first, let people add suggestions? Or email it to a moderator?
08-10-2005 #3I have read through this hole EFi forum and it made me more confused than ever. That is why i asked with specific questions pertaining to me.
08-10-2005 #4try going here: http://www.customefis.com/ if you haven't already. Be sure to check his links to other sites too. According to what I've read sequential injection is not worth the extra cost for the gain (if any.) I myself like the idea of a multiport with throttle body on a modded intake, but that takes a bit of fab. I would only worry about wide band O2 if you are going to force feed. N/A is fine with narrow band unless you're wanting to get really anal about your tuning. This is what I've gathered as I try to read up for my turbo motor build when my money tree starts bearing fruit. I haven't heard any horror stories about Megasquirt and the best thing about it is if you decide to change the style of F.I. later, you can still use the same computer. = less $$$ spent. So far that is the route I'll be taking.
John
08-10-2005 #5
