Results 141 to 160 of 258
11-18-2018 #141Registered User
- Jul 2006
- Chesapeake, VA
- 612
I love your approach to this project. head scratching and ingenuity...the way hot rodding was meant to be.
Cars are meant to be driven.
John B
11-23-2018 #142Registered User- Join Date
- Feb 2007
- Hawaii
- 225
Got my hands on an original '93 Camaro shop manual, these two ports on the right side of the plenum are vacuum ports, the upper one is hooked to the original fuel pressure regulator vacuum port, which I'm going to leave open to the atmosphere for now, and the lower one in the old original pic is hooked to an "Evaporative Emission Canister Purge Solenoid Valve"....
Hmmmmm....
The large port shown below is apparently a connection to the crankcase, and is setup as a "crankcase vent recirculation valve", which you can see in the second pic...
I think I might keep that also, but fitting the crankcase connection to a road vent tube like the older motors used would be ok too....
I think both the upper small ports are just vacuum ports, one is shown in the old pic as a brake booster vacuum connection....
I really have no idea what this hole in the top, front, right corner of the plenum is for, or what the device plugged into that hole in the second pic is....
(scratching the head....)
These rear ports I'd blocked off earlier, they are EGR (exhaust gas recirculation) ports, that I'm not going to use on this car...
The lower pic shows some of the hardware for that device...
More Later...
Willy
11-23-2018 #143Registered User- Join Date
- Feb 2007
- Hawaii
- 225
(Correction on above post....)
Got my hands on an original '93 Camaro shop manual, these two ports on the right side of the plenum are vacuum ports, the upper one is hooked to the original fuel pressure regulator vacuum port, which I'm going to leave open to the atmosphere for now, and just plug this port, and the lower one in the old original pic is hooked to an "Evaporative Emission Canister Purge Solenoid Valve"....
Hmmmmm....
11-26-2018 #144Registered User- Join Date
- Feb 2007
- Hawaii
- 225
Messed around some more with how the fuel hoses were laid out at the pressure regulator...
And bolted in a new optima red top in the trunk...
MORE pix here....
11-30-2018 #145Registered User- Join Date
- Feb 2007
- Hawaii
- 225
I put a 90 hose end on at the inlet side of that fuel filter, looks a lot better now...
I'll mount that filter on the side of the inner fender when I put the fenders back on...
11-30-2018 #146
