    Results 41 to 60 of 63
    1. #41
      Feb 2014
      Quote Originally Posted by GarageToys View Post
      The vinyl top will not be making a return.
      If it did, your's might just be the first PT car with one. ;)
    2. #42
      Apr 2017
      How's Big Black coming along?
      I have a 66 Impala and I am in the planning stages. A little unclear on what direction I want to go, but I am inspired by your project and curious how your project is progressing.
    3. #43
      Dec 2009
      Naperville, IL
      Quote Originally Posted by CLIFN8R View Post
      Slowly. I haven't been lighting the world on fire with progress. Since the last update, I have bought a Dakota Digital controller for my (future) Vintage Air unit, and made a (crude) cardboard mockup of how it will fit in the '59 Impala dash. It's going where the radio used to go. The ridetech air ride controller will go in the space below, which used to be an ashtray. I also took a spare ashtray and made a filler plate to be welded in where the stock hvac controls were:
      1966 Caprice - L92/4L80e, Ridetech/Hotchkis Suspension
      Build Thread: https://www.pro-touring.com/showthre...Big-Black-quot
      1989 Camaro Iroc Z G92 5-Speed (one of 300 as optioned). Bone Stock.
    4. #44
      Dec 2009
      Naperville, IL
      The heads are off my engine to go in for a performance valve job & the Comp VVT cam will be going in soon. I picked up some LS9 head gaskets and Holley valve covers that eliminate the coil brackets. The engine was super clean inside. It's a 2007 L92 that was pulled out in 2008 with something like 9000 miles on it.
    5. #45
      Dec 2009
      Naperville, IL
      Other than that, I've got the car up on Race Ramps and I've been just scraping, sanding and wire brushing the bottom of the car in preparation for Lizard Skin sound insulation and heat insulation. The weather is really getting nice so I'm hoping to get this finished and sprayed soon before it's 100* in the garage. Then I have to finish the firewall so the engine can go back in for good.
    6. #46
      Apr 2017
      The Fun is in the Building
      Slowly. I haven't been lighting the world on fire with progress. Since the last update, I have bought a Dakota Digital controller for my (future) Vintage Air unit, and made a (crude) cardboard mockup of how it will fit in the '59 Impala dash. It's going where the radio used to go. The Ridetech air ride controller will go in the space below, which used to be an ashtray. I also took a spare ashtray and made a filler plate to be welded in where the stock hvac controls were:
      I am in the suspension stage and struggling with whether to go springs or air ride. I like the idea of air ride but I am worried about spending $6k and getting a bouncy ride. I see you in stalled air ride. Any advice or things I need to consider?
    7. #47
      Dec 2009
      Naperville, IL
      Well, mines not on the road yet, but I've ridden in air ride cars that handle great- not bouncy. As long as it's properly engineered, the ride will be great.
    8. #48
      Jan 2014
      Austin, TX
      Love the build....its cool seeing something different!
    9. #49
      Apr 2017
      Following your lead
      Thanks, I appreciate your input.
      You don't see these cars built this way too much and your style is exactly what I would like to do with my '66. Passed on from my Mom, I'll be following similar steps....
      Cliff
    10. #50
      Dec 2009
      Naperville, IL
      Getting there. Wish I had a rotisserie and the space to use it. Got the frame and floors cleaned up & I'm about ready to pull the suspension to access the rest. Then I can finally spray the frame in black and Lizard Skin the floors.
      Engine is also progressing- Heads are back from the machine shop. Took a week off for Power Tour in June but probably only going to do a couple days and work on the car for the rest of the week.
    11. #51
      Nov 2002
      Georgetown,TX
      That is going to be one killer ride, when done. Definitely not a cookie-cutter car, for sure.
    12. #52
      Apr 2017
      That is an incredible amount of work! You definitely have an eye for detail.
      Cliff
    13. #53
      Feb 2013
      Are you losing your glove box to install the Vintage Air unit?
      I keep looking at them but haven't tried a mock up box to see how it would fit.
    14. #54
      Dec 2009
      Naperville, IL
      Well, I’ve been back after it. I plasma cut out the stock dash and got the ‘59 Impala dash mocked up in place. My brother patched the floor shifter hole because I bought a Lokar floor shifter as I’m now going to build a custom center console.
      Also re-did the front shock mounts and then pulled all the front suspension off. The rear end is out as well so I can finish prepping for paint/Lizard Skin.
    15. #55
      Jan 2019
      Enjoyed your build thread. I was looking for information on installing a 6L90 in my 65. I noticed you had ground clearance concerns. do you recall what your ground clearance would be at stock ride height?
    16. #56
      Dec 2009
      Naperville, IL
      The car hasn’t been at stock ride height in a long long time. When I mocked up the 6L90 it was lowered 3.5” on drop spindles and springs. With the trans tunnel cut out and trans jacked up into place til the tailshaft hit the floor, the trans still hung way too low. It’s been a while so I don’t remember the measurements but for any real ground clearance, the entire driveshaft tunnel would need to be cut out and raised.
    17. #57
      Jan 2019
      Which AGR Gearbox did you go with?
    18. #58
      Feb 2015
      All the holes in the firewall have been welded up. The new Flaming River tilt column is mocked-up as well as the new AGR steering box.
      Attachment 70648
      Inside you can see the new column, as well as the 4L80E mockup transmission. It probably would've fit with minimal clearancing... but it fits really easily with a giant hole cut in the tunnel.
      Attachment 70649
      Is the column that you used a direct fit or a universal one?
    19. #59
      Dec 2009
      Naperville, IL
      Quote Originally Posted by Cowansauto View Post
      It is a Flaming River universal 30 inch which fit perfect with the stock dash. The collar hits the 59 dash so I’m probably going to have to go with a longer one or modify the dash. I just have to put the seat back in and mock it up. I don’t want the wheel too close.
    20. #60
      Dec 2009
      Naperville, IL
      Quote Originally Posted by Sam Axe View Post
      The variable ratio model : https://www.summitracing.com/parts/a...t/model/impala
    Tags for this Thread
