    Page 1 of 8 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 147
      Oct 2012
      "Just Peachy" 80 Porsche 928 LS376/525
      Picked up a 1979 Porsche 928 that was wrecked. The car was stored indoors all of it's 34 years & had only 12,178 miles on her. The 79 will be used primarily for the like new, funky, pascha interior, wiring harness, etc. Picked up an 1980 roller just north of Dallas primarily for the shell, unibody, & suspension pieces. Stripped the 80 then sent it out for paint. Shaved the side moldings, side marker lights, rear wiper, door locks, headlight squirters, etc. Ordered a new LS376/525 (injected) motor then found a good used (16,000 mile)T-56 out of a 2004 Z06. The Piranha Bros fabricated a custom rear crossmember & trans mount. Stay tuned. 77tony
      Birmingham, AL
      Very cool. I would like to do a lsx 944 one day.
      Stephen
      Oct 2012
      Quote Originally Posted by srh3trinity View Post
      Glad you like, More pics, Tony
      Texan Back in Texas!
      In for updates!
      1965 Falcon Hardtop
      Mar 2010
      Rochester NY
      drooling
      Grace - 67 Camaro daily driver with upgrades along the way.
      https://www.pro-touring.com/showthre...-Camaro-Driver
      Miami, FL
      very cool. First time I have ever seen duct tape on a Porsche.
      Oct 2012
      Will be checking in on Jonathan's Falcon & Don's Camaro builds. T
      Oct 2012
      Quote Originally Posted by MrForce View Post
      Yeah, hatch lock was inoperable when the 80 roller was picked up. How about painters tape-hopefully will keep from scratching the fresh paint. T
      Nov 2011
      Lowell MI
      That's going to be a very nice car!
      Aug 2006
      Vinland Kansas,66006
      Very Cool Project!!!!!!!!!!!!
      St Louis
      Always wanted to do an LS 928. Any details on the torque tube, rear end mods to make the vette parts work?
      Oct 2012
      Glad y'all like. Dinsdale of the infamous "Piranha Bros" is the lead on this build. Dinsdale fabricated a rear crossmember and trans mount. Custom cut chrome molly axles and bell housing adapter plate by xchop for the 928 - Vette T56. T
      Dec 2009
      What a great build! Thanks for posting...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Oct 2012
      Modify Oil Pan ?
      Purchased the Holley LS Retro fit oil pan P/N 302-1.Looks like we need to either raise the motor approx 1.25" to clear the crossmember or cut the pan 1.25". Would rather cut the pan if not to much trouble to keep the engine lower in the bay and keep the center of gravity lower. This would also provide clearance on the top of the motor and the top crossmember. Has anyone cut & welded these cast aluminum pans without to much difficulty ? I do have access to a Tig Welder. TIA. 77tony
      Sep 2012
      Hildebran,NC
      Who did you get your ls3/525 through and how much was the setup if you don't mind me asking? Looking forward to purchasing one of those for my 66' nova project
      Birmingham, AL
      What cam is in that ls3?
      Stephen
      Oct 2012
      Superior Chevrolet Performance Center. Starter & starter bolt, LS Serpentine system, & LS376/525 delivered to my door for $ 8630.03 approx 8 months ago. Also have just spotted at Pace Performance. Enter P/N 19259233 for specs & pricing. T
      Oct 2012
      Go to Pace Performance and enter 19259233 into the search box. This will bring up the specs and pricing. T
      Dunwoody, GA
      I like the color you chose. Cutting and welding on the cast aluminum pans is no big deal. Before all the swap pans and various pan options came about, that's what people did to make these engines fit. In your case, I would be worried about oil drain back into the sump. You'll be making a dam in the oil pan essentially if you just cut a notch into the pan.
      Can you not redesign that portion of the cross member instead of just notching it?
      Good luck.
      Trey
      ~ Jon Hammond
      Oct 2012
      Oil pan mod
      Thanks Trey, Color is "Nordic Gold. T
