      1st Gen Camaro - Fender well install question
      I have a simple question. Is the fender well where it mates to the fender at the wheel opening supposed to go on the outside or is the well supposed to tuck inside the lip? My well was installed on the inside of the fender lip but I'm not sure it's correct because it made trying to get the well out nearly impossible. I ended up pulling the whole fender. Anybody got a picture of what's correct?
      GeoffP
      68 Camaro - LS1/T-56
      Mar 2010
      Fayetteville, NC
      Don't have a pic bit it tucks under. The bolt screws thru the fender and into the inner fender.
      Brian Peacoe
      68 Camaro Heidts Subframe and 4 link. 2015 LS3, T56.
      Dec 2009
      Quote Originally Posted by SkinsandJrfan View Post
      Yep...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      May 2012
      Calhoun, LA
      It's all most imposable to R&I them with the fenders on the car without damaging something.
      Melbourne, Fla
      pics of wheelwell on car...notice welded "nuts" towards fender..
      Pic of fender mounted... Notice "Blue" of paint, not "black" of wheelwell... hence, mounted inside fender... Hope this helps...
      Yes it helps. I hadn't separated the well from the fender yet so I wasn't aware of the welded nuts. So is the well supposed to be mounted to the car first or to the fender first? I'm just trying to get the easiest reassembly order. Thanks!!
      GeoffP
      Nov 2009
      Richfield, Wisconsin
      It is MUCH easier to mount the well to the fender first...
      Steve R.
      68 Camaro
      Thanks I thought so but have seen so many pictures with the bare wells installed that I was curious. It's not every day that I reassemble the front end of my Camaro.
      GeoffP
