Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 21 to 40 of 124
  1. #21
    Default
    When you instsalled the total control subframe connectors how close did they come to the floor pan? i just got a set andnwhen the front is forced all the way up to the floor then try and push the back all the way up they hit the foor pans before they are all the way up in position? I replaced my floor pans witrh aftermarket panels but figured everything was in position since the were clamped to rear torg box and front frame rail. I guess while it was clamped in placi could have possible forced the middle up som without screwing up the fit in front and rear.
  2. #22
    Sep 2009
    Port Richey Fl
    Default
    Quote Originally Posted by 1fststang View Post
    They hit. We marked the area where the hit and used a hammer on the floor pan
    Rusty Gillis
    Former SS/FA & SS/GA NHRA National Record Holder
  3. #23
    Sep 2009
    Port Richey Fl
    Default
    Brian had to grind and add material to the door
    After grinding
    He also had to do the same to the front
    Rusty Gillis
  4. #24
    Sep 2009
    Port Richey Fl
    Default
    The left vent window would not fit so Brian had to drill out the spot welds and bend the sheetmetal a little to allow the vent window to go in.
    The bracket on the inside of the door where the bottom of the vent window attaches was in the wrong place and had to be moved
    Rusty Gillis
  5. #25
    Sep 2009
    Port Richey Fl
    Default
    Brian had to narrow the hood than weld a strip on the back side
    Rusty Gillis
  6. #26
    The Netherlands
    Country Flag: Netherlands
    Default
    wow...great job! only thing is that despite the costs there is still a lot of modification needed to get it right....But I think the end result will be very nice (and rust free!!)
    1st 2nd
    Pro-Touring outside the USA !
    Martin's Camaro Page
  7. #27
    Sep 2009
    Port Richey Fl
    Default
    We went to install the brake pedal and steering column bracket and it would not fit. The dash was installed wrong and had to be moved toward the firewall the bracket was 1" to short from lining up. We compared the distance from the dash to the firewall on my 68 Coupe to determine the dash was in wrong.
    Rusty Gillis
  8. #28
    Oct 2012
    Default
    Very thorough work...it is very impressive & will show in a great showpiece when finished!!
    Gordon in Calgary
  9. #29
    Ca
    Default Mustang gaps
    Quote Originally Posted by rusty428cj View Post
    Nice gaps. Even with the new Dynacorn shell it's not bad. I have had my fair share of Stangs and they never fit well. 65 grills on a 64 1/2 and such. And the dreaded cowl to fender gap. If my memory serves me that was never a good fitting line-up location. When the inner fender bolt never lined up at the A pillar and you would have to elongate the hole for proper alignment. Great job, your team gets it done and executes well.
  10. #30
    Sep 2009
    Port Richey Fl
    Default
    Something fits with just a little modification
    The taillights fit after trimming the rubber seal a little
    Once the holes on the fenders were elongated the headlight buckets fit
    The amazing thing was after all the work on the door gaps the edge of the hood lined up with both headlight buckets from CJ Pony Parts. The Dynacorn headlight buckets have been on back order for over a month and I was told probably another two months before they would be available so we got them from CJ's. They are a little ripply and will require some blocking but they fit.
    Rusty Gillis
  11. #31
    Brisbane Australia
    Country Flag: Australia
    Default
    So strange seeing a project not starting with lots of rust repair.
  12. #32
    Aug 2012
    Pennsylvania
    Default
    looks like its coming together right nicely!!
  13. #33
    Sep 2009
    Port Richey Fl
    Default
    We have been working on a couple of things I can't show at this time. A modified lower front valance and a future story in Modified Mustangs & Fords magazine showing a period correct looking hood latch with an under the dash hood release.
    But I can show this
    Rusty Gillis
  14. #34
    Nov 2012
    Iowa
    Default
    Great work! As a new forum member looking for inspiration, I will be following this one.
  15. #35
    Dec 2010
    Apex, NC
    Default
    Those grinding marks look very familiar
    Glad to see you're making progress. Keep it up!
  16. #36
    Jul 2012
    Default
    Wow great craftsmanship! (not dynacorn, but you guys fixing their mistakes)
    Brandon
    2003 f250 powerstroke 2/4 drop daily driver
    1979 f250 crew cab on superduty axles
    1947 dodge 5 window coupe
  17. #37
    Sep 2009
    Port Richey Fl
    Default
    This is what Brian has been fabricating. It is an under the dash hood release. The hood required a lot of fabrication along with this latch that came off of another Ford. To find out all the details you will have to read the build story in an upcoming issue of Modified Mustangs & Fords magazine.
    Rusty Gillis
  18. #38
    Oct 2006
    Saskatchewan, Canada
    Default
    Looks like the hood latch off of a 78 - 79 Ford F150. I would think that it would take a bit of work to move the latch assembly from the hood to the rad support. Hope it will be more or less a bolt in as I don't want to ruin new paint.
    David.
  19. #39
    Sep 2009
    Port Richey Fl
    Default
    Quote Originally Posted by Blue Oval Man View Post
    David.
    Not even close to a bolt in on a 67 - 68. requires a LOT of fabrication on the hood.
    Rusty Gillis
  20. #40
    Sep 2009
    Port Richey Fl
    Default
    We removed all the suspension now it goes on a cart to prime and finish all the the bodywork
    Rusty Gillis
Posting Permissions
  • You may not post replies
  • You may not edit your posts
