Results 1 to 20 of 42
07-18-2005 #1
Has anyone on here had a CAT rod or crank break?
Curious if anyone on here has had any bad luck with a FORGED CAT rod! or Crank!
Project JUST-N-SANE
84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
07-18-2005 #2I know this is from the other thread, but it also isn't necessarily a "break? it can be faulty machine work, like the rod ends out of round, or the crank takes huge amount of mallory to balance, or break. Not a lot of guys on this site build their motors their selfs, you might try team chevelle@ chevelles.com I have seen numerous posts there but a search didn't dig up anything for some reason. Also make sure people don't get it mixed up with "Scat"
07-18-2005 #3also check nastyz28.com there are a few posts about cat there
07-22-2005 #4Registered User- Join Date
- Apr 2005
- 90
Are you thinking of useing them for your 700+ hp engine because I wouldn't. We have tryed them in some Modified stock car engines in the past with failure in nearly every case. FYI a modified engine puts out in the neighborhood of 650+ hp NA so for a 700hp supercharged car I would not even consider it.
My boss considers Callies to be the best crank in his oppinion but we use Eagle and Scat as well.
Hope this info will help you in your decision James
07-25-2005 #5Originally Posted by graycamaro
RPMs are the biggest killer of rods... What RPMS where you running in your modified stock car? (stock cars use alot higher sustained rpms than a street car with ocational drag racing)Project JUST-N-SANE
07-25-2005 #6Registered User- Join Date
- Apr 2005
- 90
Actually I was speaking of cat cranks being the failure point in these engines. The number 1 reason for rods to fail as for as spin a bearing is probably do to the fact many engine builder think if the rod is new that must mean it is on size. At the machine shop where I work we comonly have to recondition brand new rods to make them in perfectly in spec. When a customer asks us how much rpm they can turn safely we tell them as much as they want because generally they will run out of their powerband before they will damage the engine.
Stock cars generally turn 7500-8500 with a few guys turning them harder. Depends on the drivers likes, the chasis, and the track.
A guy recently brought in a new 302 Dart block and Cat crank among other parts for us to do some machine work and despite what my boss has told him about our experience with Cat cranks he is still going to use it. The engine is going to be blown and stroked so we will see how it holds up.
How much is the Cat crank and how much is a comparable crank from callies, Eagle, Scat , or Lunatti? Remember the old adadge you get what you pay for!
James
07-26-2005 #7i paid $360 for the crank and $250 for the rods (H beam).. they are both forged 4340 steel! a similar eagle crank would cost $900 and eagle rods would cost $500
Actually the crank im using isnt CAT is a made by MADDOGRACING(im not sure if it makes it better or not) The crank is supposidly good for applications over 1000 HP and the rods are good for applications over 700hp
My blown engine will not see higher than 7000rpms for short drag stip burts!Project JUST-N-SANE
07-26-2005 #8you can keep telling yourself whatever you want and using !!!! after everytime you mention that your rods are forged steel, but that doesnt' mean anything. And do you really think some place on ebay called "maddogracing" makes cranks?? Just think about it for a minute. YOu are not guaranteed a failure but for a 7000rpm motor with wha 12-15 ilbs of boost at 700hp you are asking for it!! I know what boat you are in right now, you know you shouldn't use those components but at the time you were cheap and ignorant and now you are trying to convice yourself htat it will be allright. Just forget about using those components, and get yourself a scat steel crank/rods. Just resell the stuff on ebay, if you take a small loss, who cares. It will be worth the piece of mind.
07-26-2005 #9
