    Results 1 to 20 of 26
      Near Dayton, OH
      Bonding fiberglass to steel
      What product out there is the best at bonding fiberglass to steel and NOT developing cracks later on in the paint or having the fiberglass pull away?
      I have as set of fiberglass fender flares that I want to mold into the body sheet metal. Obviously the will be held in place by screws in the wheel well lip but where they meet the fenders and quarter panels I would like to have them molded in.
      Or, would I be better off just making them bolt-on with hidden fasteners?
      Any ideas. procedures or product suggestions would be great.
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      Ramona, Ca. San Diego area
      I just spoke with my paint rep about this this week. There is a product by 3M that will make fiberglass bond with steel. I cant remember what the number of the epoxy is but if you want me to I can call again tomorrow and ask.
      67 Camaro convertible (Jinx)
      IL
      The issue you will have is not the bonding, it is where you mold the part in. What ever you use to mold it (blend it into the metal) will flex, also Fiberglas and metal expand and contract at different rates so it will always crack at some point. Unless someone has come out with a product that I do not know about. The 3m product list above is great and works very well, but it was designed to hold the fiberglass panels on to the metal frames. Think corvette the putter panels are (well were fiberglass) and the structure is metal in most areas of the car, the 3m epoxy bond the two together. Hope some of the long worded answers makes sense!
      Rick
      IL
      One more thing I think the 442 would look much better it bolted the flairs on rather then mold them in. Think GNX Grand National you see the defined lip and IMO I think it looks much cleaner. If the flairs do not have a inner lip that goes by the upper fender part then you could make a inner lip out of metal the use bolts to hold it to the fender, and this is where you can use the 3m epoxy to hold the new inner lip to the Fiberglas flare.
      Rick
      May 2009
      I agree with Rick . There are alot of great products out there from 3M , SEM , Plio Grip , Etc ..... They will all do a great job holding them together , but at some point down the road they will start to crack just because of the characteristics of the two different materials .
      Chicago
      Fusor makes a product specificly for this. I agree with the above statements you will get a crack line where the glass and metal meet Not because of the adhesive.
      http://www.autobodytoolmart.com/p-15938-19992.aspx
      Tony L
      Dec 2010
      Windy City, IL
      I've been looking for something like this to mate a fiberglass GS hood to a steel (Skylark) hood frame! Excellent info, guys, Thanks!
      '70 GS Stage 1 https://www.pro-touring.com/showthre...-1-project-car
      Restoration blog: http://1970buickgsstage1.blogspot.com/
      '70 GS 350 convertible
      '70 GS 350 hardtop
      '70 Skylark 4 dr post
      Jan 2012
      Dallas, Texas
      I had a 240Z with a lot of fiberglass attached (box flares, whale tail, etc...) and used a product from 3M called structural adhesive. The car was damaged in an accident and the adhesive did not fail. We just ground the area to bare metal, applied an adequate amount af adhesive, clamped overnight and then blended the areas with kitty hair. It worked great.
      Aug 2011
      Clearwater/FL
      sooo the flares arent gonna gain you any room in the wheel opening?? Doin flares that way is pointless IMO, makes your car look like you put fwd wheels on.....
      88 Blazer sbc
      05 300c
      corona,ca.
      andrew,we just repaired a family members carbon fiber/steel rod foot brace with 3m scotch-weld #2216 its a part a b mix very strong .but pricey at around 50.00 for the two tubes.phil
      Aug 2008
      jacksonville,fl
      I also agree that products like 3-m structual will hold, But the laws of expansion & contraction will always cause a line to show.Black showcars in sun definitely are no exception.It,s when & not if.
      For an item like fender flares, you probably could let them meet the fenders like a bolt on item would WITHOUT a blending & smoothing job & get around the issue all together.
      My thought.
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by ProTourGSX View Post
      I've done that to a couple of cars. It holds up nice but over the years (on my current car 12 years down the road) you will start to see the outlines of where the Fiberglass meets the metal. Mind you; it's not cracked!
      Near Dayton, OH
      Quote Originally Posted by SS PUNISHER View Post
      Nope. Didn't say that at all.
      We are cutting the sheet metal out behind the flares and remaking the wheel well lip so that the flare can still be screwed/glued into place to give us a little more room but these aren't huge flares. I might get a 1/2" max of more room. These really are more to accentuate the stock wheel well body lines than anything else. They also help to blend the rest of the body kit into the side of the car.
      Thanks for the help guys.
      Aug 2011
      pa
      3m panel bond will hold 2 army tanks together! only down fall is that you need a special application gun since it is a two part epoxy glue. some auto body supply stores have loaners if you ask for one. but imho that is def. the ticket when you want something to hold forever.
      May 2010
      Ballwin (St. Louis) MO
      Quote Originally Posted by motorhead8385 View Post
      I was tinking about making a fiberglass firewall and then attaching it to what is left of my current steel firewall. What do you think?
      I think that anyday you wake up sucking air on your own is a great day!
      Florida
      Burns too easy for a FIREwall.
      May 2010
      Thanks for the info. But what about "glass" bodies/firewall? Do they burn also?
      Florida
      Dunno about all glass bodied cars but the Factory Five GTM I've been building is sheet metal.
      May 2012
      Hi guys. I'm about a month away from bonding on and blending in my new glass quarters on my project and the advice I was given was ( having chosen the proper two part epoxy) the goal was to allow the glue to squish out from behind the piece and mat it down like bondo over the two surfaces before it hardens so that they become one. The logic is that if there is any gap at all that even though it won't come apart it can still vibrate at that point. Then sand it ready for filler provided the glue you choose accepts filler on top of it. The glue I will be using apparently does. I will get the name and post it after I've done my own testing.
      Connecticut
      I have had some experience with bonding fiberglass to steel. Some of the areas on my car are over 10 years with no cracks. One thing i would avoid is mechanically fastening one part of a panel and bonding another part. Sand everything down to bare metal and bond as much of the flare or body panel as possible to the metal on the car, hand lay fiberglass mat with resin for re enforcement where the re enforced filler wont work. Be sure to keep moisture out. Don't wait long to fill, blend, sand. Then apply an epoxy primer and / or finish coat. The epoxy primer will keep the moisture away from getting to the line where the metal meets the fiberglass. Do not use a lacquer based primer if the area is going to sit a while before it is completed. I use Everglass from Evercoat with great success and i am no Pro. Hope this helped.
