      Feb 2012
      Cape Coral, FL
      Building a better brake system...
      I am trying to build a complete brake system for my 1968 Camaro. So far, I have a set of six pistion Wilwoods for the front, and thats it
      I'm now trying to decide if I should just go with C5 corvette front rotors and calipers for the rear, or pony up the extra $$ for complimenting Wilwood rears. I was also planning on running a Hydroboost with a Gen 4 Camaro master cylinder.
      Anyone have any experience with this setup? Any Pro's or cons?
      Thanks in advance
      Tony
      May 2002
      Northern California
      Quote Originally Posted by kllrvet View Post
      or pony up the extra $$ for complimenting Wilwood rears. Anyone have any experience with this setup? Tony
      your half way there, might as well finish.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oregon
      Welcome to the site.
      X2...I'm with Vince, throwing C5 fronts in the rear would be a terrible match to the Wilwood 6-piston fronts (Superlite? W6A?) in terms of caliper piston area. The C5/C6 rear setup in the rear would hydraulically balance out much better, but whether you go that route or a matching Wilwood kit would be up to you. You were considering running fronts in the rear, so would I be correct to assume that you have no interest in having a parking brake?
      For the master cylinder, there are several different hydroboost solutions, however running a 1" bore fourth-gen F-body MC is probably not the best idea considering most people run 1.125" bore units with aftermarket brakes and hydroboost, and even then some would consider them to be over-boosted.
      Tobin
      KORE3
      It's what I does.
      Texan Back in Texas!
      Use the new 12" 2 piston floating set-up from Wilwood, it will match the front nicely and helps avoid knock-back issues. My kit arrived last week and I plan to tackle it this weekend if I have time.
      1965 Falcon Hardtop
      Feb 2012
      Cape Coral, FL
      How about a 1.25 diameter bore master cylinder like this one?:
      http://www.carparts.com/details/Chev...pc270901830959
