Results 1 to 20 of 36
Thread: Bolt in 4 link for 67-69 Camaros
11-22-2011 #1Starting The Transformation
- Oct 2011
- Phoenix AZ
- 129
Well,
Not too much feedback on any other products, so thought Id post something maybe a bit more interesting? Thoughts or comments are welcomed.
True Bolt-in four link suspension that can be used for both track or street, opposed to the current four link suspensions in the marketplace that require floor cutting and backseat rehab. This is a chromoly tig welded completely bolt-in four link. This is for coil over shocks and your choice of a panhard bar or wishbone for rear end locator.
Includes:
Bolt-In Chromoly Rear Frame
All hardware, nuts, bolt etc.
Bracketry
Rod ends
4 link bars
Panhard Bar
Custom Mild Steel Rear End housing with back bracing, 4-link brackets, filler cap, drain plug, vent, and your choice of bearing ends.
Options
Panhard Bar - can be used for both drag racing and street, Already Included.
Wishbone Upgrade - $99 - We recommend this for drag racing only. (Replaces Panhard Bar)
Anti-Roll Kit Upgrade - $349 - For use in conjunction with the Panhard Bar or Wishbone.
Upgrade to a Strange Rear End Housing for $199
Coil over Shocks
Strange Single Adj. w/ springs - $475
Strange Double Adj. w/ springs - $660
(Other Coil-Over Shocks, Brakes, 3rd Members and Axles Also Available)
